01 4.8 out 05 5.3 in
Old Sep 12, 2025 | 03:06 PM
JMF05LS's Avatar
Default 01 4.8 out 05 5.3 in
Replacing 2001 GMC 4.8 with 2005 Silverado 5.3 any for seeable problems i should know about?
I appreciate any input.....
Old Sep 12, 2025 | 03:23 PM
RB04Av's Avatar
5 Year Member
Depends somewhat on how much of the 5.3 you have
Old Sep 12, 2025 | 03:30 PM
JMF05LS's Avatar
i have the entire truck, the 05 is wrecked the 01 4.8 is tired.
Old Sep 12, 2025 | 10:39 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Just swap the engine. Only thing you need to worry about is oil level sensor, oil pressure sensor and cable vs wire throttle. 4.8 intake on the 5.3 will solve that issue though.
Old Sep 14, 2025 | 06:43 PM
joom's Avatar
5 Year Member
Egr ?
Old Sep 14, 2025 | 07:10 PM
RB04Av's Avatar
5 Year Member
Exhaust? TAC module? Wiring? ECM? etc. etc. etc. There's acoupla ways to go with each, depending on what you have and want to use and how much you're willing to deal with.
Old Sep 15, 2025 | 12:08 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Why are you making it complicated? I just shared the simplest method….
Regarding EGR, you can just block the port on the intake manifold or swap intake manifolds and bring over all the fuel rails and throttle cable brackets from the 4.8. Obviously tune required.
Old Sep 15, 2025 | 01:30 PM
RB04Av's Avatar
5 Year Member
Yup, one way is to take everything off of the 4.8 that's different from what's on the 5.3, and use that; i.e. just use the 05 block & heads. Probably that's the easiest. Another way is to take everything out of the 5.3 truck and put it in the 01. Where you'll shoot yourself in the shorts is trying to mix & match. As said repeatedly, "best" depends on how much you have, what shape it's in, what you want to use, etc. etc. Another consideration is inspection; if your location requires the original "accessories" to be installed and operating, or what.
mopower440
Jan 17, 2015 07:21 PM
Go5.3tt06
56
Oct 24, 2012 05:35 PM
IWantACamaroSS
36
Sep 23, 2004 04:53 PM
hyper
Sep 25, 2003 01:53 AM
