The Yukon NVG4500 Manual Transmission Swap Thread
Old Jun 29, 2022 | 06:34 PM
  #181
adriver's Avatar
Originally Posted by dantheman1540
They are all sold out which makes me think they might not make them anymore.
BUMPING this because they were out. I emailed them asking some questions, and then they changed it to back in stock. So they do have these again.
Old Jun 29, 2022 | 11:09 PM
  #182
_zebra's Avatar
makes children cry
Wait what motor is in those? The 5 cylinder thing? Are they based on the Colorado platform?
Clearly I know nothing about H3s.
What's the interior look like?
3.7 inline 5, and yeah - very Colorado/Canyon-esque but trimmed nicer & a little more robust in a number of ways.
inside looks just like the google pictures... except ours has a Core/Hurst shifter in it now (which shifts like a DREAM).
the impression i got from working with him is that since he typically builds these to order nowadays, he'll buy a bunch of common parts when people ask for a specific shifter - then make a few & then sell them, then once he's out of parts, he'll wait 'til he needs to build more before ordering again... or i think that's how it goes.
either way, compared to the original Hurst i had in my nv3500, his nv4500 unit was on par with or better than it - still a little finicky at times, and the stick angle put the ball against the console in 4th, but overall i still liked it more than the stock box (also ensure you get the correct height & pivot length for your transmission lid). and the H3 shifter he made us (of which, i only know of one or two others that were built) is amazing!
and all this thread resurrection business reminds me of right before i bought the dodge... i almost pulled the trigger on a 2000 Tahoe to do this very nv4500 swap in.
come to think of it, had i bought the Tahoe, i'd have a lot more cash in my pocket right now... but i also wouldn't have almost 1400lb of torque or 6 gears.
Old Jun 29, 2022 | 11:27 PM
  #183
_zebra's Avatar
makes children cry
Actually referring to the NV4500s behind the 5.9 cummins in the 2nd gen rams. (Not sure if they were "Ram" at that time but you get the point. That's were I saw that there is supposedly a 13in clutch upgrade. https://www.phoenixfriction.com/p-23...eed-13-in.aspx
I think I'm about to try the half quarter overfill in the Tahoe because compared to my RCSB the trans is still pretty noisy despite multiple layers of sound deadening.
As far as driver skill, the Denali isn't mine so Its not my poor skills! The new owner needs to get on hear and defend himself!
oh, and as alluded to above: only use GL-4 fluid in the nv4500 (AmsOil has some reasonable stuff that works good), and i learned from the shop that rebuilt my 4500 to NOT overfill it. that works for 3500s & 5600s but apparently overpressurizes the seals or something in a 4500 & will cause it to leak.
(ps - i also learned during my nv4500 swap that the nv3500 uses the same flywheel & slave cylinder... if you need to pinch a couple pennies).
Old Nov 4, 2022 | 04:30 AM
  #184
Coloradoroper's Avatar
Registered User
Originally Posted by _zebra
be just over 1700rpm @ 75mph, running 33s. not the worst but probably pretty doggy without a blower or big block torque
I am thinking about doing this manual trans swap in a Yukon xl with the 8.1. Really want to turn it into a off-road camping rig monster. Roof rack, bumpers, lift tires the who deal. I had been thinking a Duramax swap with the Alison, would be the way to go not great for off-road to have that weight. Still I would just enjoy the 8.1 while I do all the other stuff. BUT now I am think a manual swap would cost less, witch is good for something I will more than likely put dents in. And work better for my intended use.
Old Nov 4, 2022 | 11:30 PM
  #185
_zebra's Avatar
makes children cry
sounds fun enough!
one thing to keep in mind for your big block is that while the pickups had the Allison or ZF-S6-650 as options, the SUVs only used 4L85s.
the biggest difference that makes is that the SUVs never needed (or got) the normal 2" HD body lift to fit the bigger transmissions. that said: your options would be to either do an nv4500 with the shorter GMT400 lid or add a body lift & use the 6 speed.
nv3500
Jul 12, 2019 10:04 PM
The_W
Apr 16, 2018 09:28 PM
andrew383
Aug 6, 2009 01:23 PM
2001CamaroGuy
May 3, 2009 12:20 PM
rao
Nov 15, 2007 09:13 PM
