The Yukon NVG4500 Manual Transmission Swap Thread
#151
^^ tell that to Ed
https://www.performancetrucks.net/fo...archid=8197685
replaced his 4.3 with a 454, beat it to death, then swapped in an 8.1... then added a turbo. can't remember if he got the 2nd turbo on before the T56 swap (it's been a long time).
stock nv3500
...and then he did a 2nd 8.1 swap stick-shift truck
and even the Joe Gibbs trucks kept the stock nv3500 with their blower package. heard that one straight from the horse's mouth.
yes, the early transmissions were complete crap, but the GMT800 ones were a little better-built.
stock nv3500
Whoa schooled me! Lol I guess I should have added that my only real experience is with one nv3500 that never completely failed me but sounds like it wanted to die at any second.
Maybe it's the weight that the nv3500 doesnt like not necessarily the power?
#152
that'd be my guess. i've even read about a number of extended cab truck & suburban t56 swaps that bit the dust due to the weight, especially the ones that tried pulling trailers.
#153
I went and read that thread with the turbo 8.1 I cant believe that NV3500 stood up to that! How many miles did yours have on it when you got the new one? and what made you finally replace it?
#155
since a rebuild was ~$100 shy of a reman, i just replaced it. if i'd had the time to verify a few finer details (and hadn't already done a 4.30 swap), i would've just got a 4500 then, but i played it safe so as to not hit a snag & jeopardize my ability to move on time.
the condition wasn't too surprising considering how many times (before i had the car) that i'd been out banging gears in it, running 1/8mi with 4wd launches (once beat a '94 GT, by the way), and whatnot.
yay for custom-built tail housings!
#156
I totally understand the need for a simple fix before a move. Sort of interesting Google tells me the GMT800 nv3500 uses a 12in diameter clutch and so does the nv4500. The pedal feel different with this OEM 6.0 nv4500 clutch is so far superior than my worn out nv3500 clutch ever felt I assumed it had a much larger clutch.
Although apparently diesel guys upgrade to a 13in clutch 🤔.
I can tell you the clutch in the 408 Denali holds launches just fine😈
#158
Exactly and if the stock **** works why bother with aftermarket. Post up those launch videos just for fun though.
#159
#160
Although apparently diesel guys upgrade to a 13in clutch ��.
I can tell you the clutch in the 408 Denali holds launches just fine��
... unless you meant the old 6.5s
and i technically only went through 1 clutch: i bought it at 126k & supposedly the stock clutch, so i put a new one in (needed it bad). then when i broke a rod & did the engine swap at 148k, it needed the v8 clutch, so i pulled out the one with 20k on it that looked new. then i put 70k on that clutch, at which point i also replaced the trans. now at 247k, this clutch is still doing fine.
driving skillz + tripod = solution to your excuses
