Yank TT3000 or Pacesetter LTs/ORY
Old Sep 25, 2006 | 02:40 PM
KevinF56's Avatar
Default Yank TT3000 or Pacesetter LTs/ORY
hey everyone. i'm looking to do one more mod to my truck then call it a year as far as spending money on it. i currently have an AEM intake, a cat-back exhaust and a Wester's tune. i was planning on doing pacesetter long tubes and the off road y pipe, but then i started reading about torque converters and they sound like a very good mod. if you had my current mods and had to pick either the headers or the converter, what would you pick? my tranny is bone stock. if i were to get the TC would i need to add anything to beef it up a bit? shift kit maybe? oh and i have a 2004 RCSB 5.3L 4x4 and it's my daily driver. thanks in advance for any input.
Old Sep 25, 2006 | 02:44 PM
i would go with the headers, you could do without the converter for a while until you are planning on a cam or something
Old Sep 25, 2006 | 02:51 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
In a heavy 4wd truck you need more power out of the hole. While the ocnverter doesnt give you more power it puts you into your powerband quicker. A converter made teh biggest difference in my truck besides getting a tune. All lt headers with an ORY will do is cut the nuts out form under your truck down low with a stock tune and close to stock hp. Once you have a converter then get headers that way you wont notice the little bit you lost down low
With that said get a custom tune first then stall then lt headers. Thats the way I would do it if I started all over again.
Old Sep 25, 2006 | 03:09 PM
KevinF56's Avatar
i have a custom tune already.
eventually i plan on getting a cam, stall, headers, e-fans, etc. but i want to do either the stall or headers now.
would a shift kit in combination with the stall be a good idea? also i've been reading and it looks like the TT3000 is very streetable. will it work well when i get a cam in the future?
Old Sep 25, 2006 | 03:12 PM
silver-mod-o's Avatar
Hunt&Fisherator
converter
Old Sep 25, 2006 | 03:20 PM
KevinF56's Avatar
Originally Posted by silver-mod-o
converter
that's what i'm thinking. my truck is really lacking in the low end. i mean the thing wont even light up the rear tires without brakeing. the more i've read about the converter the more i like it. plus it sounds a lot more fun.
will my stock tranny be fine with the converter swap?
Old Sep 25, 2006 | 03:22 PM
you will need to get a bigger transmission cooler with the converter because they will generate alot of heat, a shift kit would be good too cuz the converters usually soften up your shifts some. the shift kit will also make your trans perform better and last longer
Old Sep 25, 2006 | 03:24 PM
04BlackSilverado's Avatar
Converter
Old Sep 25, 2006 | 03:28 PM
KevinF56's Avatar
Originally Posted by 04BlackSilverado
Converter
hey steve havent seen you post in a while. wanna go to the track one more time before it closes for the season?
Old Sep 25, 2006 | 03:29 PM
Hunt&Fisherator
word on that... the SK will help you out.. or even just for a servo upgrade...
