Would this work???
Old Dec 24, 2006 | 03:47 PM
Dirty 30's Avatar
LS1Tech Whore
Default Would this work???
This wheel adapter (adapter is 1.75" thick)....
6x5.5" lug (6x139.7mm) To: 5x4.5" lug (5x114.3mm)
and these wheels...
Weld prostars 15x10 5.5bs 5x4.5 bolt pattern
Would it work, Will the wheels stick out??????????????
This is for a 03 Reg Cab Reg Bed with the stock rear end.
Old Dec 24, 2006 | 04:07 PM
Mangled03gmc's Avatar
Baltimore Whore
you will need at least a 16 inch rim to work on your truck. 15;s will hit the calipers and unless you shave them down...
Old Dec 24, 2006 | 04:28 PM
Dirty 30's Avatar
LS1Tech Whore
Im willing to grind them if its possible.
But would that setup work???
Old Dec 30, 2006 | 05:01 PM
jgun's Avatar
and these wheels...
where can you get these adaptors and how much are they? I think they should work with the right back spacing on the wheel
Old Dec 30, 2006 | 06:37 PM
Dirty 30's Avatar
LS1Tech Whore
I found some perfect 6 lug to 5x4.75 lug (F-body style)
Ebay Item # - 160066795178
They sell them at www.truckn-store.com
Here are those other adapters...
http://cgi.ebay.com/ebaymotors/6-LUG...QQcmdZViewItem
Old Dec 30, 2006 | 06:46 PM
litreddevil's Avatar
Banned
i bet you will have to cut the stock suds shorter
but it should work
Old Jan 5, 2007 | 12:46 PM
Dirty 30's Avatar
LS1Tech Whore
TTT! So i recieved my adapters that are supposed to be 6 lug chevy to 5 lug 5x4.75 (fbody). I get to test them out and found out that they are actually 5x4.5 (mustang)
So i could of got them new for about $50 more if I would have known.
Old Jan 5, 2007 | 06:43 PM
02BlueStepside's Avatar
The wheels will stick out before the adaptors.
Old Jan 5, 2007 | 09:52 PM
Dirty 30's Avatar
LS1Tech Whore
what about a 15x10 with 7.5 back spacing with the adapters?
Old Jan 6, 2007 | 10:44 AM
Probably still stick out just a little after the adaptors, but it would be close.
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
