will a detroit locker just drop in? no reshiming the sides?
14 Second Truck Club
A locker will be stronger and will have spool like traction in a straight line, but will have open diff charecteristics in turns. They can be noisy and also a little squirley in the rain, but no more so than the eaton really.
I always sell the Eaton for the average street/strip guy, but for your application I dont think it is going to be a long term solution although it is a big improvement over stock.
You should also consider a solid spacer rather than the cruch sleeve and welding the axle tubes. The T/A covers are also an improvement but they are pricey, the other 2 things are cheap and easy. The solid spacer is usually under $5 and the welding is just about free if you have a welder.
Originally Posted by JRsilverado
I don't know about Detroit but I just finished installing a Powertrax and it just dropped in a couple pieces at a time. It took about 1 1/2 hours to do the whole install. That's including quit a bit of time scraping the old gasket off, having to back track because I wouldn't follow directions
Originally Posted by Start2Fabrication
To clarify, and for search posterity, the Powertrax No-Slip drops right in. The Powertrax Lock-Right, despite what several parts houses say, only works in the OBS trucks
Also, the Powertrax/Lock Rite is a completely different style than a Detroit Locker since you dont even need to remove the case from the truck, just the spider gears. Detroit makes an EZ Locker which is similar, but I dont care for any of those style diffs in high stress applications.
Summit Racing said they were shipping me the Lock-Right for the 8.6", but when I went to install it, the locker was about 3/16-1/4" too wide for the 8.6" open case. I then found the 1921-LR part number to match the 8.5" OBS rear
$15 worth of fluid and gasket down the
er
er
5.3Caprice
Nov 7, 2015 08:56 PM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
