Why can't I read my transmission fluid level?
Old Jun 16, 2009 | 05:06 PM
RandomHero's Avatar
Default Why can't I read my transmission fluid level?
Well my transmission issues continue to line up and kick me in the nuts one after the other.
I haven't had any fires lately which I suppose is good.
However, I went to finally go drive the truck and it's stuck in gear. I check the transmission fluid and it's reading high already. I've had this problem before with the reading being off so I add a bit more fluid and suddenly the problems go away.
What I can't understand, is why is my transmission fluid level reading so high?
I'm checking it on a level surface with the trans temperatures anywhere from 80*-180* with the same results.
It's reading almost an inch above the "hot" line. When I add fluid, the problem goes away.
Anyone have any tips? I've literally checked it 30 different ways and it reads the same.
Oh and trans specs are:
vacuum mod
Borg Warner 3-4 clutch pack with kolene steels
Reenforced input drum
beast sunshell
hd-2 shift kit
larger stator shaft
corvette servo
29 element sprag
bushings and bearing have been replaced
and several other things I'm neglecting.
I was hoping something in the list might have something to do with it.
EDIT-I have also tried my other dipstick so I know it's not the dipstick
Old Jun 16, 2009 | 05:36 PM
thunder550's Avatar
High on diesel fumes
Have you tried draining it and setting it to the correct level?
Old Jun 16, 2009 | 05:38 PM
RandomHero's Avatar
Sure haven't although I know for a fact it was low when I checked it the first time(I lost over 2-3 quarts of fluid) and it read at the top of the "hot" hatches.
Old Jun 16, 2009 | 06:19 PM
charcold-bowtie's Avatar
If youve just added fluid it can be a pain. Make sure the stick isnt "sweeping" it off the dipstick tube on the inside.
And fluid can easily be drained out of your truc cool FYI...
Old Jun 16, 2009 | 06:24 PM
00ChevyScott's Avatar
Wearin' da big hat
Has it always been this way even when it was stock?
Old Jun 16, 2009 | 08:32 PM
RandomHero's Avatar
Well it's been this way ever since I had my transmission rebuilt 2 years ago. It was re-rebuilt last Christmas as well(broke the 3-4 clutch pack), and has always been the same way. I don't get it.
Old Jun 16, 2009 | 08:56 PM
2007chevy5.3l's Avatar
Man i have the problem of not being able to see the damn fluid on the stick, i have perfect vision but trying to see the fluid level makes me feel blind
Old Jun 16, 2009 | 08:58 PM
RandomHero's Avatar
Maybe I'm the same way then. I have perfect vision, but I can't tell where it's hitting the sides and where the fluid level is.
Old Jun 16, 2009 | 09:01 PM
Hell yeah, plus the fluid gets all streaked down the stick and throws me off so im like WTF! Wipe it off dip it again and try to get a better reading. Its almost like the fluid is invisibly clear lol
Old Jun 16, 2009 | 10:01 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
I am going to ask one silly question, So dont take offense please. But you mentioned it was hot and on a level surface. But what about running ?
