Where to get trans parts
Old Jul 23, 2008 | 10:24 PM
dirt track racer 81's Avatar
Default Where to get trans parts
Need to find a place to get 3-4 clutch packs..that are worth a damn
Old Jul 23, 2008 | 10:28 PM
RandomHero's Avatar
raptor transmission and Oregon performance. I got my parts from both of them. We'll see how my trans holds up with a 150 shot, but it's doing fine with 6400 shift points and a ss3600 converter.
Old Jul 23, 2008 | 10:29 PM
if you ever spray it..but ill look em up thanks mark
Old Jul 23, 2008 | 10:40 PM
RandomHero's Avatar
I'm in the negotiations process for a nx kit
Old Jul 23, 2008 | 10:45 PM
bout time good luck with it. vacuum modulator..what does it do
Old Jul 23, 2008 | 10:49 PM
RandomHero's Avatar
It controls the line pressure of your shifts based on the amount of vacuum the engine sees. Basically it ditches the shitty computer controlled shifts and resorts to an old school method of shift firmness.
Old Jul 23, 2008 | 10:55 PM
which one should i get http://www.oregonperformancetransmis...e=ALT-57757BHP or http://www.oregonperformancetransmis...de=NTP-K51353Z
Old Jul 23, 2008 | 11:14 PM
RandomHero's Avatar
I run the first set in my transmission. I'm pretty sure FLT uses the first one(or a variation of it) in their level 5.
Old Jul 24, 2008 | 06:58 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Gotta ask if FLT is still selling parts only. Noticed the site has changed a while back, and never thought to ask. May even go back to using the 46-MOD (vac mod) if I can fine tune shift pressure (was way to hard with the last trans that had it).
Old Jul 24, 2008 | 11:40 AM
built408's Avatar
Vacuum Modulator, 8 blue stripe clutches, 8 full thick kollene steels, alto apply and backing plates... Spacer plate drilled to .110 and accumulators blocked off. Thats my setup and have yet to burn it up with 12,000 miles on it and about 50 bottles.
