Where to get trans parts
Old Jan 19, 2009 | 07:48 AM
  #21
built408's Avatar
No offense, but I have bad luck with both of those setups. The 1st has steels that are only .059 thick. Which will not dissipate the heat well. And the z-pack Ive just never had luck with.
Old Jan 19, 2009 | 05:16 PM
  #22
dirt track racer 81's Avatar
Originally Posted by Dirty Dave
You can get the parts here in wichita from A@reds (autry enterprises). I have a brand new transgo vac mod kit i'll sell ya. I used a z pac in mine. Some people like the alto better though. The really high horspower guys use the high energy clutches with .080 kolene steels and a .120 pressure plate. A@reds have all the hot rod goodies for good prices.
are you the one dewayne my old boss at d&g dyno talked to a while back?
Old Jan 19, 2009 | 06:01 PM
  #23
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Another Parts supplier we use is called The Perfect Shift here in PA call 5706197532 ask for RICH tell him frank at performabuilt told you to call him for parts
Old Jan 19, 2009 | 08:56 PM
  #24
Dirty Dave's Avatar
That would be me. I am going to bring my truck down to see him soon. My new motor has about 1000 miles on it and needs some dyno time.
Old Jan 19, 2009 | 08:57 PM
  #25
thanks frank, are they around the same price as oregon? also ive heard that high rpms are hard on 4l60s. would this part be helpful since my motor will run 6700-6900 rpm? http://www.oregonperformancetransmis...ory_Code=4L60E
Old Jan 19, 2009 | 09:02 PM
  #26
built408's Avatar
Definitely put those springs in there, if not, buy a Transgo HD-2 kit, and those springs come with the kit.
Old Jan 19, 2009 | 09:06 PM
  #27
let me know when you bring it down, if im not workin ill try to come down there
ill go ahead and get it. i have no clue what the idiots that originally built it put in there. anything else i should put in there?
Old Jan 19, 2009 | 09:12 PM
  #28
built408's Avatar
.500 boost valve, billet servos, vacuum modulator, alto wide band, good set of 3-4's, beast, double cage sprag, and hardened hi-rev pump rings.
Old Jan 19, 2009 | 09:27 PM
  #29
alright so with a vacuum modulator it does away with the computer controlling the transmission. what all needs done in the computer? does it have to be shifted manually, which is no problem since i have a b&m shifter and do that already. sorry for the dumb questions ive just never read up on a vacuum modulator
Old Jan 19, 2009 | 09:28 PM
  #30
dirty dave you have a pm
