Where to find axle u-bolts?
Old Jan 16, 2013 | 08:13 PM
Ferocity02's Avatar
Default Where to find axle u-bolts?
I've bought two sets of u-bolts on eBay now and neither one have been good. The most recent set I got, the top of the u-bolt isn't even square, so it won't sit properly on the top of the leaf spring. It will only touch at the corners of the springs and probably wear them down or damage them. In the pictures below, the eBay u-bolt is on the left, and a GM u-bolt is on the right. I need ones that are slightly longer than the GM bolt, around 9.5" in length. But longer than this isn't an issue as long as there are sufficient threads.
So, where can I buy u-bolts that are long enough and are flat on the top? Any GM bolts long enough? Other sources? Thanks!
Old Jan 16, 2013 | 08:16 PM
03regcab sierra's Avatar
Maybe the z71 u bolts would be the correct length
Old Jan 16, 2013 | 08:20 PM
MPFD's Avatar
11 Second Truck Club
I got grade 8 u bolts when I put on my caltracs from autozone. They were for a block style lift kit and were way over length. I had to cut them down after they were installed.
Old Jan 16, 2013 | 08:25 PM
Ferocity02's Avatar
You're probably right! Anyone have the part numbers?
I just found some Husky ones on Rock Auto, here's a direct link: U-bolts
2000chevysilverado's Avatar
Oriellys autozone napa or a machine shop
Old Jan 16, 2013 | 08:26 PM
Ferocity02's Avatar
Yes, I need these for my trac bars also. How long were the ones you got? I didn't see any there when I looked. Their site has some but the lengths range from 18-20"
Old Jan 16, 2013 | 08:35 PM
moregrip's Avatar
what a rush!
this is where i bought mine
Suspension U bolts for leaf springs and custom applications
Old Jan 16, 2013 | 08:41 PM
snakeatinZ's Avatar
Him downstairs
Pep Boys had the grade 8 ones for my truck. My stock bolts did not have enough threads after removing the 2" lift blocks.
Old Jan 16, 2013 | 08:50 PM
MPFD's Avatar
It's been a few years but I'd say they were every bit of 18".
Old Jan 16, 2013 | 11:54 PM
Ferocity02's Avatar
Thanks for the suggestions! I went ahead and ordered a set of 9.5" Husky brand ones from Rock Auto for $33 shipped, not too bad.
flatblack83
Jan 3, 2026 07:10 PM
santoy956
Sep 10, 2015 03:12 PM
chevstang421
Sep 10, 2015 09:16 AM
11MPG
Sep 8, 2015 04:52 AM
iregret
Sep 7, 2015 01:20 PM
