what size slick?
Old May 5, 2008 | 06:23 PM
fastrt's Avatar
11 Second Truck Club
Default what size slick?
I am runin a 28x10.5-15 now on a 15x8 wheel. I found a set of 29.5x9x15's today and wanted some input from you guys on what size slick should I run. mods is sig plus 3.73/eaton soon. The 28's gave me the times in the sig. my fronts are 275/45/20's at 29.7" tall.
thanks
Old May 5, 2008 | 06:49 PM
dlt76028's Avatar
I wouldn't go taller then the 28"s you have know. your times will improve alot one you install those gears/stall.
Old May 5, 2008 | 07:35 PM
7845's Avatar
Banned
with nothing major done to your truck i would actually run a 26" tire.
Old May 5, 2008 | 09:48 PM
fastrt's Avatar
I think 26's are too short. I got the 28's for a bill but they have dry rot in places and they leak. I got m/t tubes but need to drill the valve stem hole out on my wheels just a hair for the tube's valve to go thru it. I just wanted to get some ideas/opinoins before I spend any more time or money.
Old May 6, 2008 | 12:47 AM
7845's Avatar
Banned
nope...even with 410s 26" work fine. as long as your motor can turn rpms run the best tire/gear ratio to put you near peak hp true the traps.
going to large on tire will hurt ET. some will say the taller tire helps traction, i 60' better in the past with 26" over 28"... setting up truck and learning how to drive is a big part of 60's
Old May 6, 2008 | 10:06 AM
fastrt's Avatar
I see you point, I just thought 26's were for cars and 28 up were for truck apps with no weight dist. The 28's are to wide, I want to go to a 9 inch wide tire. I found some for $100 but they are 29.5's. I will look into the 26's.
thanks
dsbodley
Nov 14, 2015 09:46 PM
GMCtrk
Oct 5, 2015 11:18 AM
old motorhead
Sep 29, 2015 08:22 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
