What 4L60E do I have?
Old Jun 21, 2007 | 09:59 PM
thehemi's Avatar
Default What 4L60E do I have?
I bought a 4L60E really cheap from a wrecked full-size van.
The van was not present, so I'm not sure what year. How
can I find out more about the tranny?
Some of the tranny markings... 4L60E M30 24204457
It appears to be a 2-piece bellhousing. The bolts to remove
it are accessed from "inside" and not from "outside". FWIW.
I don't think the bellhousing is the exact same as my 4.8 V8.
Is this a Vortec-based 4L60E? If so, can it still work behind
my 4.8 engine? Can I just swap the bellhousing with an LS1
based unit and, if so, will the 4.8/5.3 wiring still work okay?
Old Jun 21, 2007 | 11:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
LMAO at your sig performabuilt
Old Jun 22, 2007 | 05:44 AM
slowec's Avatar
Originally Posted by performabuilt
if you can post a picture taken from the front of trans I can tell you/
I think you should celebrate your new involvement with the truck crowd with some Really cheap group purchases!!! Whatathink???
Old Jun 22, 2007 | 07:24 AM
SSSBLKOUT's Avatar
woohoo, $1000 6L80e's foreveryone
Old Jun 22, 2007 | 07:54 AM
KevinF56's Avatar
phenomenal idea
Old Jun 23, 2007 | 09:54 AM
thehemi's Avatar
Here you go...
What do you think?
Old Jun 23, 2007 | 12:23 PM
thehemi's Avatar
This is a vortech based unit and will not fit behind your engine
That figures. I'm not going to drop the coin to convert it.
Actually, I think I might've found a 5-speed anyways while
I was researching the 4L60E... now that's dumb luck.
I was going with a 4L60E since the T56s were pricey and I
could never find a 5-speed forsale when I was looking...
Thanks for the help!
Old Jun 23, 2007 | 03:13 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
This is a vortech based unit and will not fit behind your engine , not only is the bell wrong but the input shaft and the pump stator are wrong , Now it could be modified to work if you changed the input shaft, pump stator or assembly and bell from and LS1 type unit.
spoken truth. Ask me how I know.
Take a look at the input shaft (left)... that'll fit to TCs for Vortech vehicles. The input shaft on the right will fit in TCs for LS-based vehicles with the 4.8/5.3/6.0. See the difference b/t the tips of those shafts? The pumps are different. The drums are interchangeable, so you do not need to press the shaft out of the housing. There's a sponsor (--->) that sells those in a 298mm & 300mm input drum assembly.
Wolftrk99
Dec 3, 2015 08:12 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jamesm32
Sep 24, 2015 11:49 AM
RONIN LSX
Sep 19, 2015 05:33 PM
