were to buy addco swybar sets?
Old Jun 14, 2008 | 01:48 AM
05chevyguy's Avatar
Default were to buy addco swybar sets?
were is the best place to buy addco sway bar kits? i cant find any on ebay... 2005 rcsb silverado ....
thanks
Old Jun 14, 2008 | 08:00 AM
bud8fan's Avatar
thanks
i got mine at www dot neverenoughauto dot com .....i called and they had the front and rear as a set for my truck....
Old Jun 14, 2008 | 08:58 AM
Rick_Vor's Avatar
I got mine from them also. Fr + Rr for $275 shipped to CA.
Rick
Old Jun 17, 2008 | 10:08 AM
05chevyguy's Avatar
ok so i see it says that some factory hardware is needed.... well my left swaybar endlink is shot...... the bolt is ok... its the sleeve that broke... pretty much all i have is the bolt and bottom washer... do i really need anything?
Old Jun 17, 2008 | 10:45 AM
bud8fan's Avatar
that comes new in the box...
Old Jun 17, 2008 | 04:06 PM
05chevyguy's Avatar
what factory stuff do i need though?
Old Jun 18, 2008 | 10:41 AM
05chevyguy's Avatar
bump...
Old Jun 18, 2008 | 10:57 AM
KySilverado's Avatar
Basically it needs the sway bar bushing mounting caps... If you already have a front swaybar as it sounds you do you are good to go.
Addco Note #7: This bar must be used if you have an existing bar on your vehicle. This bar is a larger diameter than the factory bar, but uses the same mounting points as the original factory bar. It requires the use of special hardware that was factory installed. This kit may not contain all the hardware that is required for installation. This item cannot be used without the original hardware. If your car didn't come with an OEM bar, you'll need the mounting hardware from a junkyard or dealership.
Old Jun 18, 2008 | 11:01 AM
05chevyguy's Avatar
would that be the bushings that look like "C's" and are attached to the underside of the frame?
Old Jun 18, 2008 | 11:45 AM
Yes. The kit might come with them but you would still need the holes and bolts to mount the sway bar.
CammedZ71
Aug 30, 2015 04:17 AM
BigEd_72455
Aug 8, 2015 07:37 PM
Sexyrado327
Aug 2, 2015 04:08 PM
rudvirus
Jul 15, 2015 09:31 AM
lo4x4
Jul 5, 2015 05:58 AM
