were to buy addco swybar sets?
ok so i see it says that some factory hardware is needed.... well my left swaybar endlink is shot...... the bolt is ok... its the sleeve that broke... pretty much all i have is the bolt and bottom washer... do i really need anything?
Basically it needs the sway bar bushing mounting caps... If you already have a front swaybar as it sounds you do you are good to go.
Addco Note #7: This bar must be used if you have an existing bar on your vehicle. This bar is a larger diameter than the factory bar, but uses the same mounting points as the original factory bar. It requires the use of special hardware that was factory installed. This kit may not contain all the hardware that is required for installation. This item cannot be used without the original hardware. If your car didn't come with an OEM bar, you'll need the mounting hardware from a junkyard or dealership.
