weight difference
Old May 16, 2009 | 08:06 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default weight difference
between the 4l80e & the 4l65/60e whats the difference between them if anybody knows as far as weight & dimension...puttin a lq4 in a 86 toyota mini-truck & tryin to find out how much of the floor pan will have to be cut thanks guys
Old May 16, 2009 | 08:39 AM
Dark Halo's Avatar
Im going to say it is about 80# difference and the 4l80e is shorter by a inch or 2
Old May 16, 2009 | 08:42 AM
OneQwikSS's Avatar
no noticeable height/width differences though?
Old May 16, 2009 | 08:59 AM
Dark Halo's Avatar
the 60 gets a little more narrow toward the tail shaft than a 80. If I remember I ca try and post a pic of a 80 beside a 60. I will not be until monday before I can do so, Im staying at my Moms for the weekrnd getting the truck ready.
Old May 16, 2009 | 09:03 AM
OneQwikSS's Avatar
no big deal just tryin to get a round about answer i know either way the floor is getting cut just curious on how much it was going to be...and honestly i was more concerned with the weight difference between the two thanks for the help!
Old May 16, 2009 | 09:27 AM
marlboroman71818's Avatar
are you sure about 80lbs? they did not feel that far off when I lifted both of them by hand
Old May 16, 2009 | 09:05 PM
vanillagorilla's Avatar
He's actually pretty damned close with that 80lb guess.
60E: 163.2 lb wet
80E: 254 lb wet
http://www.media.gm.com/division/200...tic/index.html
Old May 16, 2009 | 09:11 PM
00ChevyScott's Avatar
Wearin' da big hat
how much more fluid does an 80e take?
Old May 16, 2009 | 09:38 PM
charcold-bowtie's Avatar
a **** load
I put a gallon just in the TC, I think around 15 quarts total. Depending on the cooling system
Old May 16, 2009 | 10:35 PM
SilverDog's Avatar
Kind of off question but how much does a 86 toyota mini-truck weight.
