w/ a 4/6 how wide can you go
Old Mar 15, 2008 | 07:35 PM
1bad5.3's Avatar
Default w/ a 4/6 how wide can you go
I was thinking I would do a 275/40/20 in the front and a 295/40/20 in the rear...... does anyone know if this will fit w/o rubbing?
Old Mar 15, 2008 | 07:39 PM
Derek @ EDO's Avatar
FormerVendor
whats the backspacing of the wheels?
Old Mar 15, 2008 | 10:35 PM
StrokerAce03's Avatar
With the correct backspacing/offset it shouldn't be a problem. Close, but it could work.
Old Mar 16, 2008 | 08:41 AM
1bad5.3's Avatar
I do not know . how would I find out?
Old Mar 16, 2008 | 10:17 AM
TexCrew's Avatar
look up the specs of the wheels you want
Old Mar 16, 2008 | 07:54 PM
I have a 4/6 with 275/40/20's all the way around. Front is fine, the rear I think I could fit a 305 with 5.5 backspacing on a 20x10 with the fender lip rolled. It would be really close!
Old Mar 17, 2008 | 05:49 AM
1bad5.3's Avatar
is the back spacing stamped on the wheel anywhere?
Old Mar 17, 2008 | 05:50 AM
1bad5.3's Avatar
I am not sure where these came from they came with the truck.
Old Mar 17, 2008 | 11:53 AM
You can measure the backspacing. It's not stamped on the wheel. If you are buying the wheels, it will state the backspacing or you can get the backspacing where you want it for custom wheels.
pewter00
11
Oct 20, 2023 05:40 AM
thompson
Dec 27, 2017 06:48 AM
lycominghunter
26
Sep 25, 2015 07:50 AM
pewter00
Sep 13, 2015 11:14 AM
pewter00
Sep 11, 2015 09:32 AM
