Violent Shaking while braking!!
Old Mar 26, 2009 | 12:01 AM
00ChevyScott's Avatar
Wearin' da big hat
Do the front wheel hubs spin freely, or do they spin with some resistance and come to a stop somewhat quickly?
If it is spinning freely, all the grease has probably worn out and leaked out of the bearing and it is shot.
Old Mar 26, 2009 | 11:00 AM
coryhussey's Avatar
they do spin somewhat freely, but that is only with me spinning them with my fingers round and round. They sound good and i can hear the bearings and grease when i spin them.
Old Mar 26, 2009 | 11:48 AM
budhayes3's Avatar
PT's Slowest Truck
Do you hear the hum in the front or rear? Try jacking up the front end, put your hands on the wheel and tire assembly at 12:00 and 6:00, and rock it back and forth. If there is any play the bearing is shot. You may not be able to hear a bearing noise by spinning the wheel while it is in the air since there is no load on it. You can also diagnose a wheel bearing noise while driving...turn the steering wheel left and right and see if the noise changes pitch or gets louder or even goes away. If you turn the wheel left and the noiose gets louder the right bearing is usually at fault, since your loading that side of the truck with it's own weight from body roll. Vice-versa if it happens while turning right. The symptoms sound like a bad wheel bearing, but there definitely are other possibilities...
Old Mar 26, 2009 | 05:04 PM
what about the ABS?
isnt there a speed sensor that can go out, and cause the ABS to activate no matter what pressure is used?
Old Mar 26, 2009 | 05:09 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Modern_Muscle
what about the ABS?
Yes, the front speed sensors are known to get rust between them and their mating surface moving them further away from the reluctor wheel and getting a false signal. This can usually be felt while driving slowly and braking normal, you'll hear the abs motor activate and the pedal will pulsate. Try driving about 15mph and applying light pedal pressure and see if the ABS activates.
This would not explain the humming noise though...
Old Sep 14, 2010 | 12:40 PM
Closer_2001's Avatar
I'm having a similar issue with my '03 RCSB
Any progress made here ?
Old Sep 14, 2010 | 02:00 PM
Daryn's Avatar
Formerly darynC-10/23/10
alignment?
Old Sep 14, 2010 | 05:58 PM
Originally Posted by daryn c
alignment?
It distinctly feels like it is coming from the rear end.
I might bolt up with Tahoe or TBSS Wheels / tires to see if it changes anything.
RustyD
May 23, 2016 07:04 PM
dantheman1540
Nov 1, 2015 02:59 AM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Alco
Sep 4, 2015 04:08 PM
