Violent Shaking while braking!!
Do the front wheel hubs spin freely, or do they spin with some resistance and come to a stop somewhat quickly?
If it is spinning freely, all the grease has probably worn out and leaked out of the bearing and it is shot.
Do you hear the hum in the front or rear? Try jacking up the front end, put your hands on the wheel and tire assembly at 12:00 and 6:00, and rock it back and forth. If there is any play the bearing is shot. You may not be able to hear a bearing noise by spinning the wheel while it is in the air since there is no load on it. You can also diagnose a wheel bearing noise while driving...turn the steering wheel left and right and see if the noise changes pitch or gets louder or even goes away. If you turn the wheel left and the noiose gets louder the right bearing is usually at fault, since your loading that side of the truck with it's own weight from body roll. Vice-versa if it happens while turning right. The symptoms sound like a bad wheel bearing, but there definitely are other possibilities...
This would not explain the humming noise though...
KINGCYCLES
Oct 2, 2015 10:21 AM
