Turbo 400 will it fit?
The Th400 is shorter, here is some info, these guys are 2wd, but there is the info you need for the adapters, and gearing
https://www.performancetrucks.net/fo...ht=th400+th350
I understand why you would want to swap, but do you drive much freeway, because your rpms will be pretty high cruising
and lockup! you will be making a big step down to go to a 400. the 4l80E will do just as good with more gears and electronic advantages! not to mention you will change nearly everything trans related to make it work.
I believe they use the same gear sets and clutches sept for the OD
