TrueTrac operation with ABS/4WD
Old May 8, 2012 | 06:06 PM
Default TrueTrac operation with ABS/4WD
Has anyone with a truetrac or valutrac had any issues with their ABS freaking out or kicking in auto 4X4 unexpectedly? I have had a spider gear-less lunchbox locker and it freaked out both. Any input would be appreciated
Old May 8, 2012 | 07:26 PM
greasemykey's Avatar
my truck isnt 4wd but it never bothered my ABS and i even changed my gears. but im curious... did you change your gears and not calibrate the computer?
Old May 8, 2012 | 08:41 PM
Stock everything. Just put the locker in it and drove it in auto 4x4 in the rain. Going around a corner it tried to do a power slide at about 20% throttle and continued trying after I let off the gas. The problem is that the ABS/4WD sensor is in the tailhousing of the T case and the lack of standard spider gears throws off the rear driveshaft RPM around corners in relation to the front. I don't want to run a helix style posi if it's gonna cause the thing to spaz again but I'm not a big fan of clutch style posis either. The rip off of a detroit locker called the Grizzly claims to be ABS compatible but I really don't see how
Old May 8, 2012 | 10:55 PM
ayousef's Avatar
I have an Eaton locker and no problems at all.
Old May 8, 2012 | 11:10 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Mine works just fine all year long. 2WD, 4x4, snow, ice, extreme cold, etc. ABS works perfectly as well.
In fact, several trucks up here have the Detroit Tru-Trak without any problems.
I've also ran the Eaton LSD, and I think I liked it better. It was friendlier in parking lot maneuvers.
Old May 9, 2012 | 06:03 AM
Given the choice, I'd prefer the "more locked" posi over one that slips a lot. I had a lunchbox locker in my Jeep and never noticed it was back there but it had like 2/3 the power and 2/3 the weight not to mention my truck has so much idle torque, the locker would lock backing out of a parking spot. I definately don't want another locker but it sounds like a truetrac or valuetrac might be just what I need
Albertachevy
Sep 22, 2015 10:28 PM
fortune46x
Sep 16, 2015 08:18 AM
97aztecgt
Sep 10, 2015 05:07 PM
11MPG
Sep 8, 2015 04:52 AM
Dezert1500
Jul 30, 2015 02:51 PM
