TruCool 40K question
Old Aug 8, 2010 | 04:59 PM
  #51
fastnblu's Avatar
If your not running in winter, then no. Even so, Ihave to run mine in winter, since this is my DD, w/. no bypass, & don't expect to have any problems.
Old Aug 8, 2010 | 05:31 PM
  #52
04ColoradoZQ8's Avatar
Well thats what I thought where I'm going to run it in addition to the factory cooler.
Old Aug 8, 2010 | 07:02 PM
  #53
budhayes3's Avatar
PT's Slowest Truck
Sounds like a nice setup....my trucool has been performing flawlessly, through the 95-100* days we've been having, with me driving "spiritedly" (gotta romp on the new trans and verter ). I just check it periodically for leaks after the install...knock on wood, so far, so good
Old Aug 9, 2010 | 04:20 AM
  #54
Yeah I run the hell out of my truck and I know the trans is getting a beating.
So I'm going to do another filter and fluid swap when I do the cooler and temp gauge install. Any special you guys recommend?
I was also thinking of a differant trans pan that hold more fluid, but I'm not 100% it will clear my low profile transmission x member.
Old Aug 9, 2010 | 05:40 PM
  #55
budhayes3's Avatar
PT's Slowest Truck
I use the factory filter and gasket kit, and regular old conventional DexIII...Valvoline went in my FLT Level7 when I did the swap. I'll probably give them a call when I do my next filter to see what they recommend. My truck came with the factory deep pan which seems to be working out fine. I've considered a Deep pan like the B&M, but I don't think that it would work out with my y-pipe.
Old Aug 11, 2010 | 09:18 AM
  #56
Yeah the 4L60E in the 355s(colorados/canyons) came with a factory deep pan too.
Well with the help/advice from you guys and my fellow 355ers I have come out with the remaining info I needed to make this cooler install easy as pie!
The lines are super easy with this one part:
The Hayden 397 fitting for the 2000+ GM truacks
http://www.transmissioncoolers.us/Me...roduct_Count=2
Old Aug 13, 2010 | 03:56 AM
  #57
Bigbus's Avatar
Help !
I cannot find the proper fitting to fit my cooler.
its a tru cool 40k, and im running russell -6 lines, i have the lines, the 4 -6 swivel 90's and the tranny fittings.
the fittings i ordered to fit the cooler are -6 flare x 3/8'' npt and it wont fit.
am i missing something simple ?
need to get this figured out so i can get everything hooked up and going.
Dan.
Old Aug 13, 2010 | 11:46 AM
  #58
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Bigbus
Help !
Dan.
Does this help?
https://www.performancetrucks.net/fo...rucool+fitting
Old Aug 13, 2010 | 03:26 PM
  #59
Bigbus's Avatar
On order from Summit !
will let you know in 2 - 3 business days haha
but seriously thanks for the help !
Dan.
Old Aug 14, 2010 | 08:49 AM
  #60
budhayes3's Avatar
PT's Slowest Truck
Glad to help Dan
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
