THE Tru-Cool 40K GVW Transmission Cooler Install Thread
Old Oct 15, 2010 | 09:24 PM
  #61
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
So I think I'm gonna install mine tomorrow. How much fluid will I lose when I disconnect the stock one? I wouldn't think it would be much, maybe half a quart?
Just trying to figure out how much I need to buy before I tear into it.
Old Oct 15, 2010 | 09:31 PM
  #62
Atomic's Avatar
I have a gauge for that
I drained my cooler mostly and put in about a quart when I was done.
Old Oct 15, 2010 | 09:47 PM
  #63
BlackGMC's Avatar
Resident Retard
So is the fitting for the Radiator 1/4 pipe?
Old Oct 15, 2010 | 10:51 PM
  #64
SnakeOiler's Avatar
No - it is a 5/8 18 inverted flare, same as the cooler. Or if you need a stock replacement fitting: https://www.performancetrucks.net/fo...00&postcount=4
Old Oct 16, 2010 | 12:44 PM
  #65
fastnblu's Avatar
Originally Posted by Atomic
Finished today using the list I posted earlier in the thread. I made two lengths of about 8 feet so I have 4ft of extra if I need it for anything. I also have enough slack where I can use this on an 80e if I need to. AN hose fittings are tricky if you have never done it before. And getting to those trans fittings was a tight fit for sure. ...
b4vwannabe, how much fluid you'll lose when u disconnect the stock cooler isn't a whole lot. 1 way to minimize it is use some plugs & have the hoses up in air, rather than hangin down just dangling there oozing tranny fluid all over. My .02. Sure u won't get every drop, but it helps.
Corey, 1/4 pipe is only on tranny. No where else. SnakeOiler gave the rest of details.
Old Oct 16, 2010 | 05:12 PM
  #66
BlackGMC's Avatar
Resident Retard
Cool, thanks guys, since i will be down grading converters shortly I am gonna need to run the lines through the radiator so it will get up to temp faster when winter comes.
Old Oct 19, 2010 | 07:26 PM
  #67
AndysC3's Avatar
Looks awesome Atomic. Did you bypass the radiator? Also looks like you mounted it below the radiator, behind the bumper.
Old Oct 19, 2010 | 08:16 PM
  #68
Atomic's Avatar
Yea, I bypassed the rad. My heat exchange is too big to put the trans cooler.in front of or behind it so I had to put it behind the bumper
Old Oct 20, 2010 | 04:06 PM
  #69
Lucille's Avatar
Does it matter if the cooler is mounted so that the lines come in from the top instead of the bottom? I suspect I will have the same problem as you trying to use the trucool and larger HX.
Old Oct 20, 2010 | 04:22 PM
  #70
Atomic's Avatar
Nope, shouldnt make a difference.
