Transmission tubing size?
I’m installing a trans cooler and I’m going to install a AN x tube adapter. I just need someone to verify the tubing size. I’ve seen someone mention 5/16” but then I’ve also read something about 3/8”. I also have read the trans fittings are 1/4”. Can someone please tell me what size I need to buy?
Hunt&Fisherator
3/8 stainless compression fittings worked well on mine adapting it from hard line to hose. I used a tubing Union to go from the stock lines to the new tubing, ran up to the cooler with more stainless hard tubing and just a short section of braided hose to isolate the cooler from vibration. I also deleted the stock radiator cooler. Just straight from the trans, to big cooler up front, back to the trans. We don't need the pre-heat down where we are, and eliminates the failure point of the radiator cooler rupturing and killing a trans.
Thanks guys, I got it installed a couple of weeks ago. I ordered the 3/8 x an adapter and installed the trucool 40k.
Ben, do you still live in setx? It's been a while.
The LT1 That Could
01-04-2005 09:41 PM
