Transmission tubing size?
Old 06-16-2018, 04:17 PM
JFOLM's Avatar
Default Transmission tubing size?
I’m installing a trans cooler and I’m going to install a AN x tube adapter. I just need someone to verify the tubing size. I’ve seen someone mention 5/16” but then I’ve also read something about 3/8”. I also have read the trans fittings are 1/4”. Can someone please tell me what size I need to buy?
Old 06-16-2018, 08:51 PM
2002_Z28_Six_Speed's Avatar
4L60E fittings are available in -6 and -8. I had -8 when I had an auto tranny. -6 hose is equal to 3/8.
Old 06-16-2018, 11:06 PM
JFOLM's Avatar
I’m not needing a 4L60E fitting. I need to know the factory tubing size for the hard cooler lines.
So I can buy a compression x AN fitting.
Old 06-17-2018, 09:53 AM
kbracing96's Avatar
The factory hard lines are approx 3/8", actually I believe they are 10mm so slightly over 3/8"
Old 07-29-2018, 07:15 PM
Hunt&Fisherator
silver-mod-o's Avatar
3/8 stainless compression fittings worked well on mine adapting it from hard line to hose. I used a tubing Union to go from the stock lines to the new tubing, ran up to the cooler with more stainless hard tubing and just a short section of braided hose to isolate the cooler from vibration. I also deleted the stock radiator cooler. Just straight from the trans, to big cooler up front, back to the trans. We don't need the pre-heat down where we are, and eliminates the failure point of the radiator cooler rupturing and killing a trans.
Old 07-30-2018, 04:45 AM
JFOLM's Avatar
Thanks guys, I got it installed a couple of weeks ago. I ordered the 3/8 x an adapter and installed the trucool 40k.
Ben, do you still live in setx? It's been a while.
Old 07-30-2018, 05:23 AM
Hunt&Fisherator
Yeah, I'm still hiding around here. Numbers still the same. I'm not playing with hot-rods much these days but I still have toys
Old 07-31-2018, 12:03 AM
JFOLM's Avatar
Good deal man. Glad to see you're still around.
I don't have any toys either, but my kids sure do!
Old 07-31-2018, 10:35 AM
Hunt&Fisherator
I know what ya mean. We're expecting our third little one in October lol.
Dont be a stranger!
Old 08-05-2018, 06:23 AM
JFOLM's Avatar
Dont be a stranger!
Congrats man, we have 2 kiddos ourselves.
Same to you.
vicalma03
07-22-2008 10:58 AM
sdimer350
11-08-2007 02:11 PM
Quik
11-01-2007 07:32 PM
—Bauker™—
03-04-2005 02:03 AM
The LT1 That Could
01-04-2005 09:41 PM
Quick Reply: Transmission tubing size?
