Transmission Temperature Gauge
Old Jan 22, 2006 | 03:14 PM
BlackLM7's Avatar
Default Transmission Temperature Gauge
I recently installed an electrical Autometer transmission temperature gauge. What temperature should I expect? The highest reading I got was 125* and it took about 15 mins. of normal driving to get there. Is this normal?? BTW, I have a factory transmission cooler.
Old Jan 22, 2006 | 04:04 PM
smooth_addictions's Avatar
as far as i have seen that is normal. put a load on it and see what it does then.
Old Jan 22, 2006 | 05:01 PM
SnakeOiler's Avatar
Based on the temps in Charleston, right now, it should at least go up to 150* sitting in traffic. 125* sounds about right if you're highway driving. When its colder you'll be lucky to see it get to 125*. The summer months, it should run right up about 180*
Old Jan 22, 2006 | 07:48 PM
Post
I had a whole entire different gauge cluster sent to me from US Speedos.
My 2005 VHO's original gauge cluster didn't come with the tans temp gauge at the lower left corner of the cluster. US Speedos sent me an O.E. gauge cluster with the o.e. trans temp. Of course it's not factory looking.
I've only had it in for two days now. I'm seeing temps around 105-115*F
The summer months will pick that up though.
Jim
Old Jan 22, 2006 | 08:05 PM
BlackLM7's Avatar
OK, I appreciate the responses. I thought 125* was too low. For some reason, I always thought the engine and transmission operate at approximately the same operating temperature.
blownss27
Aug 14, 2020 08:27 AM
simman22
Jan 21, 2017 10:27 PM
andrewlong
Nov 9, 2016 09:38 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
kalikid06
20
Oct 13, 2015 07:37 AM
