Transmission question
Old Oct 27, 2014 | 06:23 PM
Hubcap's Avatar
Default Transmission question
Ok got the trans rebuilt in my 01/5.3 A couple months ago I only put about 900-1000 miles on it. And lost 3/4 gear. Drop the pan found clutch material (black sludge stuff) and the trans fluid was metallic/red. So called the guy up took it him. he asked "what stal I was running". I took him a FTI SB 3200. I have a trans cooler it runs through the radiator and through the cooler. He said the highest I can run is a 2600 the TB converter. I just Oder a yank ss3600. He said he won't warranty another trans cuz of the converter.
I run that same converter on my 180k mile tans and worked fine for 10-15 thousand miles. The only reason I got a rebuilt one is I felt like it was getting weak.
Now my question is is a 3600+ stall to big to run on a weekend/ sometimes a daily driven truck?
Old Oct 27, 2014 | 09:02 PM
GMCSIERRA5.3's Avatar
3600 imo is badass for daily/weekend truck alot of people on dailys dont go past 3200..and if i were you i would get a trucool 40k cooler bypassed..the radiator is junk also make sure to clean out the lines..
Old Oct 27, 2014 | 11:21 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Sounds like another shitty builder to me.
If your tune was done prior to the built transmission, You should have your tune re-adjust after a modified/built transmission. All the upgrades are designed to speed up ***** and increase line pressure and a tune that is set for a basically stock trans can blow a modified one apart.
Old Oct 28, 2014 | 08:53 AM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
3600 in a daily will just be fun.
Old Oct 28, 2014 | 03:44 PM
Hubcap's Avatar
Well I'm going to pick it up today. So we will see I have a 3600 going in. So I'm think the line pressure was turned up. my tuner came over last night turned it back down to stock. So I think it is going to work at least I hope.
But I think your right. About the shitty builder. I've talked to a lot of transmission shops. They said " as long as lock up is working. And you have a trans cooler you should be fine " so this is my last time to drive a hour and a half to get the damn trans
Old Nov 6, 2014 | 04:23 PM
NorthTexasConverter's Avatar
LS1Tech Sponsor
That is indeed a shitty builder.
I would not advise turning the pressures down back to stock, especially in a performance application. You're builder may have shitty diagnostic skills but if the pressure was raised that was probably intentional. A proper main line pressure is critical to transmission survival. How much power do you make roughly if I may ask?
ferrellrooster
Mar 6, 2025 03:22 PM
zblee
63
Jun 10, 2023 01:25 PM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bsn1989
Jul 16, 2015 08:20 AM
