Transmission output shaft / transfer case angle
Old Mar 7, 2016 | 12:00 AM
lxcoupe's Avatar
Default Transmission output shaft / transfer case angle
What are everyone's output shaft angles? If I put an angle finder on my transfer case output shaft seal, I get -4.1 degrees which seems excessive to me? The diff is +0.2 degrees. I have no vibrations but I keep getting a drip from the transfer case seal even after replacing it twice.
Old Mar 7, 2016 | 01:03 AM
Turbo6.0's Avatar
I do not know about the angles, but is the slip yoke in good shape? Pitting or worn? Also check tail shaft bushing for wear, wiggle the slip yoke up, down, and side to side.
steves86ta
Mar 30, 2016 07:59 PM
lxcoupe
Mar 3, 2016 02:58 PM
69TA
Feb 23, 2016 09:23 PM
cj847
Feb 20, 2016 02:13 PM
40series
Feb 15, 2016 04:47 PM
