transgo shift kit install
Old Dec 4, 2006 | 09:36 PM
jakebdb56's Avatar
Default transgo shift kit install
are they hard at all to DIY? I've never done one on a 4l60e. I know they can be done with the transmission inside the vehicle (per transgo's site). I'm a gearhead and I do all the work on my truck with ease. I firmly believe that I can do it no problem, just haven't done one. How long did it take? any special tools needed?
its really not a bad deal for like 120 bux. I could really use one in my truck.
thanks,
jake
Old Dec 4, 2006 | 10:29 PM
Yukon 400's Avatar
It's not that hard to install, just a little time consuming when installing one for the first time. One thing that you may want to get is a pair of small snap ring pliers for the boost valve and some tranny assembly lube for the check *****, I have teh instructions if you want to take a look at them before the install.
There were some set backs, they were the bost valve coming out after the install and forgetting a washer on the 4th servo.
Old Dec 4, 2006 | 10:34 PM
blake2kz71's Avatar
snap ring pliers and i think vaseline will work fine for the check *****.
Old Dec 5, 2006 | 01:10 AM
jakebdb56's Avatar
sounds good. I think it'll really help liven up the transmission. even though I've upped the shift pressures and modified the shift times, I think it'll make it shift quite better than it is right now.
how long did it take from start to finish roughly? was it maybe a 2-3 hour job?
thanks,
jake
Old Dec 5, 2006 | 06:06 AM
adam1803's Avatar
mine on my 4l80e took about 5 hours but there was a lot of bullshiting and drinking going on at the same time. You'll want to bring your shift pressure back to stock when your done or you will damage the tranny since the shift kit will up the pressure too.
Old Dec 5, 2006 | 02:50 PM
Tootall's Avatar
I can give you a ride in mine this weekend to give you an idea. I've got "a" washer in it, and I'm thinking about taking it out. It's enough for the g/f to say "alright, what did you do"
PM me your number if you wanna meet up.
Old Dec 5, 2006 | 03:02 PM
BlackGMC's Avatar
Resident Retard
Sounds like my GF
Old Dec 6, 2006 | 12:40 AM
jakebdb56's Avatar
sounds good. where in houston you at?
Im gonna be busy all day saturday prolly. you got any time sunday?
thanks for the info guys
Old Dec 6, 2006 | 08:51 AM
Tootall's Avatar
I'm at Westheimer and the belt, but I'm headed over to my parents house in League city to take out the spacer, and put a pin in that I left out. I'll be outa there around 4pm. I'm open to whatever eithe way.
thunder550
Oct 8, 2015 04:53 PM
1slwgto
Aug 16, 2015 06:40 PM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
zaathur151
Jul 6, 2015 10:57 PM
