Transgo Install Pics
#31
Originally Posted by Vince @ FLT
Are you giving it minimal throttle? Also what rpm's are we talking about with these readings?
#34
Maybe the checkball is missing. The intermediate clutch feed circuit (used for 1-2) is the most likely to jam the checkball into the separator plate and get it stuck, so maybe the installer just decided to take the easy way out and avoid the posibility entirely.
For what it's worth, the intermediate and direct circuits on mine are drilled to .096" and overdrive is .120". That comes out too harsh at low throttle for the 1-2 and 2-3 so I tuned down pressures for those at low throttle. This has two benefits: It helps prevent the checkballs from oblonging the holes in the separator plate and it makes for snappier downshifts since there's less pressure to bleed off and larger exhaust passage (checkball hole + feed orifice).
lycominghunter
Aug 15, 2015 12:26 PM
therock
Jul 25, 2015 09:23 AM
