Transfer case gasket leaking?
Old Oct 23, 2008 | 09:48 PM
1BadAction's Avatar
Registered abuser
Originally Posted by built408
Are you sure your not overtightening them? causing the gasket to rip?
he has a point. Might want to pick up some new fasteners and tq it down to the factory spec.
Old Oct 23, 2008 | 10:12 PM
1989k1500's Avatar
Theres studs in the t case so Im sure its made for more than one use but I'll see what factory torque spec is and try that the next go around with some more blue loctite.
Old Oct 23, 2008 | 10:15 PM
1989k1500's Avatar
Im gunna put a new adapter on and torque it to factory spec with some blue loc tite and cross my fingers.
Thanks for the help guys.
Originally Posted by KySilverado
Not trying to offend. Sorry if I did. You did say tear, not wear
May want to consider having your current adapter machined to make sure its flat. May be a little cheaper than a new one if you have access to a mill. Thats what I plan on doing with my leaky one.
I dont take offense at much of anything.
A friend of mine has an adapter that he bought from the dealer and never used so I'll probably snag that from him and put it on.
Since you and thunder dont have problems Im gunna go ahead and assume its not a 4wd launch issue.
Old Oct 23, 2008 | 10:45 PM
1Bear's Avatar
I've never had a problem with leaks and I used the GM gaskets as well, however a lot of shops just use RTV in this area. I couldn't bring myself to do it, as I figured the General wouldn't have put a gasket there if they didn't think it needed one.
Old Oct 28, 2008 | 06:04 PM
black4x4's Avatar
I have the same trouble as you and I do my fair share of 4lo launches. I've had mine apart 3 times this summer and its starting to seep agian. I also stopped getting the factory gasket and just started putting a fat bead of rtv blue on it.
Old Oct 28, 2008 | 09:46 PM
oldred95's Avatar
According to GM VIS my 99 had the transfer case replaced under extended warranty and it clearly has a big fat bead of RTV sealing it. The RTV is sealing fine but the front output seal leaks like a siv and at a glance makes it look like the case halves leaking.
lucas287
31
Jan 12, 2021 06:18 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
dselby25
Sep 11, 2015 05:03 AM
sTNT971
Sep 11, 2015 02:38 AM
mayko
Sep 7, 2015 12:24 PM
