Trans wont down shift.
Old Dec 27, 2008 | 08:09 AM
JDC's Avatar
JDC
Default Trans wont down shift.
A few times lately when i came to a stop it wouldnt shift down. Id have to pull it down manualy to take off again. Now it wont go into 1st at all it shifts up no Problem. Any ideas. Its a 4L60E
Old Dec 27, 2008 | 10:15 AM
JDC's Avatar
JDC
Ok I switched the P/N switch seems to work ok now. But there is a about a 3 to 4 sec. delay in the indictor. any ideas on this prob.
Old Dec 27, 2008 | 11:48 AM
FLT's Avatar
FLT
FormerVendor
I would check your connection terminals to make sure there is not any corrosion. Hard to believe that a P/N switch fixed your problem unless it was out of adjustment. What you have described almost sounds like a cracked 1-2 accumulator piston. I have seen when they start to crack oil pressure on one side of the piston will leak into the 2nd gear accumulator clutch circuit. Basically applying the band when it should not be applied. As the pistons crack gets bigger the problem gets worse. Usually a band failure is what we see with cracked plastic pistons. If in fact yours is cracked get an aluminum one and this will not happen again. Good luck. Vince
Old Dec 27, 2008 | 05:53 PM
JDC's Avatar
JDC
Went for a second drive and it seemed to shift fine still. Vince Ive got a 408 to install in the spring and was wondering if your level 4 4L60E would handle the torque and what converter would you suggest for it.
Old Dec 28, 2008 | 07:16 PM
RADO_4U2NV's Avatar
I had the same problem with shifts opened my tranny and this is what I find.
Rebuilt and works fine now.
Old Dec 28, 2008 | 10:08 PM
FLT's Avatar
FLT
FormerVendor
I would look at the list of preferred converter vendors on our site and give them a call about a converter recommendation. They will help you decide what will be best for your combination. As for the trans I would like to know what your rw #'s will be in order to help you make that decision. I feel that the level 4 is good to around 400-450 at the wheels depending on the weight of the truck. Feel free to give us a call when you have time. Vince
Old Dec 29, 2008 | 06:26 AM
JDC's Avatar
JDC
Is the accumulator located on the right rear of the trans.
Old Dec 29, 2008 | 07:16 AM
FLT's Avatar
FLT
FormerVendor
Yes it is in the right rear of the pan area held in with three 10mm headed bolts. Vince
Old Dec 29, 2008 | 11:36 AM
JDC's Avatar
JDC
Smile
Ok thanks Vince. Tranny did act up again last night Ill check out the accumulater piston this week. And what tranny is in the 2005 silverado SS because the wife thinks i should up date.
Texas5.3_1251
Mar 5, 2016 08:10 PM
06 4.8
Sep 11, 2015 10:36 AM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
