trans shutters?????
Old Jul 20, 2011 | 04:59 PM
lafnatu's Avatar
Default trans shutters?????
i have a 2000 siverado 2500. when driving around 55-65mph if i give it very easy throttle it shutters, feels like the tranny. if im in a turn like an on ramp it does it more often. truck has 136k miles. trans was flushed w mobile one at 90k. anyone have any ideas?
Old Jul 20, 2011 | 05:53 PM
Vince B's Avatar
Is this a 4l60e or an 80e? Sounds like you are probably in 4th gear with the TCC engaged if I had to guess. Does this vibration go away if the TCC is off?
Old Jul 21, 2011 | 02:28 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Most "shuddering" with the converter locked, at light/low loads(right before the 'verter unlocks) is from an ignition misfire, not the transmission.
Old Jul 21, 2011 | 05:24 PM
lafnatu's Avatar
its an 80. im not sure what tcc is so i dont know if its locked or not but it is running a little ruff at idle also. no check engine light on tho.
Old Jul 22, 2011 | 06:09 AM
Vince B's Avatar
TCC is torque converter clutch. This is the function of the transmission designed to increase gas mileage and also reduce heat from the converters rated stall speed. In your case it sounds like you might have some issues with the way your engine is running. I would probably address this first. I think what might be happening when you feel the complaint is the engine is misfiring. With the tcc being applied its more noticeable because the clutch is adding some load to the situation. I hope this helps you understand a little better. Vince
Old Jul 22, 2011 | 06:19 AM
lafnatu's Avatar
Yes. Thanks everyone! Guess I have to figure this misfire out. I put ngk's in it about 7k miles ago. It ran great until 500 miles ago. Still have original wires n coil packs.
Texas5.3_1251
Mar 5, 2016 08:10 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
