trans shutters?????
i have a 2000 siverado 2500. when driving around 55-65mph if i give it very easy throttle it shutters, feels like the tranny. if im in a turn like an on ramp it does it more often. truck has 136k miles. trans was flushed w mobile one at 90k. anyone have any ideas?
TCC is torque converter clutch. This is the function of the transmission designed to increase gas mileage and also reduce heat from the converters rated stall speed. In your case it sounds like you might have some issues with the way your engine is running. I would probably address this first. I think what might be happening when you feel the complaint is the engine is misfiring. With the tcc being applied its more noticeable because the clutch is adding some load to the situation. I hope this helps you understand a little better. Vince
