Trans may be toast...again
Old May 22, 2011 | 12:50 AM
magnetized's Avatar
Default Trans may be toast...again
[Rant on] Had the trans rebuilt about 2 1/2 years ago by a local builder after I noticed a slip on the 2nd to 3rd shift. About 60k miles later I noticed that the trans temp reached about 200 driving around this afternoon and the shifts were a little jerky. Go out for a bite to eat tonight and the shifts are much harder than usual, with a jerk and crunching sound with them. Stopped and smelled the fluid (smells burnt to me), so now it's parked until I can call the pros on Monday and get some answers and options. Good thing I don't race the truck, this would get expensive if I had to replace one of these bastards frequently [/Rant off]
Old May 22, 2011 | 09:46 AM
Vince B's Avatar
Is your tcc working? In some cases your computer will disable the tcc operation because of a code stored in your computer. This will result in a high line pressure condition. Being that you have hard shifts and your trans was running hot its a possibility that this is the case. I would get your vehicle scanned asap to see if this might be a simple fix. HTH Vince
Old May 22, 2011 | 09:49 AM
00ChevyScott's Avatar
Wearin' da big hat
I drive around with no TCC lockup and keep it in 3rd as well. No problems with tranny overheating, but I do have the 40k cooler.
Old May 22, 2011 | 10:11 PM
magnetized's Avatar
Interesting, I will check this out. Thanks for the tip
Old May 22, 2011 | 10:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Do you have a cooler on the trans??
Old May 25, 2011 | 07:44 PM
magnetized's Avatar
Yeah, it has the factory cooler that comes with the towing package.
Texas5.3_1251
Mar 5, 2016 08:10 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
