Trans cooler
Old Jan 2, 2018 | 08:26 AM
turboal1's Avatar
Default Trans cooler
what is the right way to plum a trans cooler ?
before or after the rad ?
Plate or tube cooler ?
Old Jan 2, 2018 | 09:16 AM
darkirish63's Avatar
Everything you need is right here...good luck.
https://www.performancetrucks.net/fo...thread-470284/
Old Jan 2, 2018 | 09:20 AM
Drspencer's Avatar
5 Year Member
After the radiator, otherwise, what's the point? Depends what's in your price range as far as the type of cooler. Consider the factory one, as small as it is, keeps guys around 180 degrees according to the dash. If you don't have a cooler, you'll need adapter fittings, can't remember who makes them but I have them at home in the package. The adapter fittings go from the clip style to a -6 AN fitting.
Old Jan 3, 2018 | 03:17 PM
Radiator acts like a warmer up until trans temp equals coolant temp. But after that its a fluid to fluid cooler which is very good at transferring heat. I prefer for my trans to run under coolant temp (i also live in the south) so I generally run them independently with a dedicated fan on a switch. I also monitor temps with a gauge and pan mounted sensor. You'd be surprised how much the little 8/10/12 inch ebay fans can do.
Old Jan 4, 2018 | 01:07 PM
turboal1's Avatar
Default cooler
that thread was totally useless for me.
no factory cooler, no 80e, diff rad hookup.
just 2 lines going into the bottom of my rad.
same type of rad clip in fittings.
Ferocity02
Mar 13, 2013 08:46 PM
EVILGMC
Nov 9, 2011 09:06 PM
wot_denali
Sep 22, 2009 01:05 PM
Mangled03gmc
Jul 25, 2008 10:18 PM
primetime
Mar 25, 2002 11:17 AM
