Trans Brake or 2-Step?
Old Aug 22, 2012 | 08:51 PM
FI FREAK's Avatar
formerly BlacKSS2oo2 (9-20-2012)
Default Trans Brake or 2-Step?
About to get a Stage 4 4L80E from Jake's Performance. I was wondering what you guys preferred.... Go ahead and get the trans brake installed or just go with the MSD 2-Step? Need to build boost either way.
Thanks!
Old Aug 22, 2012 | 09:05 PM
black00chev's Avatar
Slowest turbo build ever!
I think foot braking while using a 2-step would be fun. But the brakes will only hold back so much power.
Old Aug 22, 2012 | 09:09 PM
trans brakes are very hard on your drivetrain so if you DD it or have stock parts behind the transmission, go with a 2step. I can build 6psi with my 2step at 3000rpm
Old Aug 22, 2012 | 09:16 PM
JoeyGC5's Avatar
I love my Jakes Probrake. If i get off my butt i'll prob add a 2-step. but now with the brake i can build 6-7lbs, where before i could onky do 1-2 on footbrake with hydroboost.
Old Aug 22, 2012 | 09:26 PM
Vince B's Avatar
I would say both if you are considering a trans brake. Reason being is with the two step and on the brake we are trying to keep the heat down in the trans. This is something that has been done with power glides, th400, C6, TF-8 and other transmissions for years. I will say make sure to keep an eye on the trans temps and also try not to stay on the brake to long because you will hurt the pump in that trans.
Old Aug 22, 2012 | 11:39 PM
FI FREAK's Avatar
On that note what is normal operating temps for the 4L60 and 4l80?
Old Aug 23, 2012 | 06:04 AM
Vince B's Avatar
The cooler the better. In most cases I would say temps should be between 140-190*.
Old Aug 23, 2012 | 06:42 AM
slowec's Avatar
BOTH!!!
Fun factor goes off the chart!!!
Old Aug 23, 2012 | 06:58 AM
AndysC3's Avatar
I was thinking about eventually doing a 2 step. Mainly for the sound but the off the line consistency would be awesome.
Old Aug 23, 2012 | 04:24 PM
slowec's Avatar
Installing a MSD8733 is easier than picking up the phone and ordering one too!
SLOPONY
20
Oct 18, 2016 06:05 AM
ss454327
Oct 17, 2015 03:43 PM
Jake99
Aug 8, 2015 07:56 AM
mrgrim
Jul 8, 2015 08:12 AM
