tranny question
i installed the second gear vett servo and the fourth gear servo. and drill a few hole in the seperator plate.
now my second gear seems to pull harder than my first gear. even at light throttle i'll be going along and when it shifts to second it accelerates faster than when in first. all at the same part throttle. is this normal? was my secong gear ust slipping that bad before? it just seems like my first gear doesn't pull as hard as it use to. either that or my second gear pulls harder than it use to so it feels like first gear is slower. so which is it? lol is there a chance that the servo's are too tight? with a pry bar you can push in on the fourth gear servo and case and it goes in abit. so there for it has play and the instructions called for like .125 or something play and i can push the cap in that far at least.
anybody?
can anyone tell me what the semptoms are if your servo's and pin are too tight? as in i put the longer pin vette servo's two hd2 shims and billet servo. should i take the two shims out?
