!!!tranny issues on 4l60e !!!
I have a 01 GMC swb 160k has servo and shift kit! OK so my issue I ran into was truck runs fine on (D) gears shift firm and everything up to cruising and highway speeds but when I come to a stop then get on it like “punching it" it does not want to pass gear rpm gauge revvv up to like 5500+ until I release the pedal! So I tried it again but manually shifting it this time “punched it" and goes into gear the moment I shift! I tried power braking it on D to burn the tires and again it highly revs high and does not even burn em or spin them! Has 22" wheels!! HOW SHOULD I START APROACHING THIS ISSUE? MUCH HELP WOULD BE HIGHLY APPRECIATED!
Thanks for your feedback bud! And I haven't literally checked inside the pan just yet but I did check tranny fluid and it seems that its holding at normal level or equivlant to second dot on dipstick and thats @ tranny warm!
[QUOTE=greasemykey;5200243]i did not mean that you are loosing fluid from the transmission more that your gaskets are not sealing and fluid is bleeding out of the passages in the valve body[/QUOTE
Where would u recommend starting off? U think shift selonoids and filter would be a good start?
zblee
63
Jun 10, 2023 01:25 PM
Abuckeye
Aug 19, 2015 06:11 PM
MileHighSierra
Jul 22, 2015 11:19 PM
