Trailblazer converter upgrade from YANK
Old Apr 14, 2005 | 03:16 PM
  #31
gonzo 6.2's Avatar
Thanks for clearing that up.What specificly would be the difference of the 2400 Yank verse's taking a new OE truck converter and restalling it?OEMs are furnaced brazed right?
Old Apr 14, 2005 | 04:08 PM
  #32
Yank's Avatar
LS1Tech Sponsor
The converter we use was a special pump blade that is not used in the USA it was built as a high stall from GM, and we go a little more, also the turbine hub spline is heat treated for the extra abuse as is the pump drive hub.
yes, the factory converter for the 4.8, 5.3,6.0 and 8.1 are brazed but the trailblazer 4.2 converter is not.
You can go to about 2300 to 2400 in the 5.3 but it will not have the high eff. that our 2400 does the diff. is about 3 % less than the stock unit about
94% where our unit will run 96-97% not a big deal but but enough to move you RPM to MPH a little at the top of 2th and 3th gear
Old Apr 15, 2005 | 09:33 AM
  #33
gonzo 6.2's Avatar
Originally Posted by Yank
We do offer a 2400 stall upgrade on that converter.
the price will be the same $250.00
as all the features will be included that are stated above
the performance will be very close to the stock TB unit
The stock carbon weave was GM designed to slip all the time)
with our new lining the clutch feel and holding is greatly improved!
this upgrade includes :
1, increase the stall in converter to 3100 RPM
2, change the clutch
3, install Kevlar lining
4, rebuild -- install new parts as needed
5, balance & pressure test
6, Epoxy paint
all this for just $250.00 plus shipping
the turn around time is very short!!
call us to set up your appointment today
Thank's for looking
Does this include a special pump blade and heat treated turbine splines and pump drive hub?
Old Apr 15, 2005 | 09:51 AM
  #34
Yank's Avatar
LS1Tech Sponsor
it is everything except we do not have any more of the special pumps so we have to rework the factory unit
it will have as stated but in 2400 stall
Old Jul 25, 2005 | 07:57 PM
  #35
slimcracka's Avatar
sounds to good to be true... so if u did have this stall instock what kinda money we looking at? i need one now..
GXPJAY
Feb 13, 2022 08:15 AM
Stainless Works
Apr 10, 2016 04:34 PM
lteone
Aug 12, 2015 02:10 PM
BennyB
Aug 1, 2015 08:48 AM
maxspeed05V
Jul 19, 2015 07:08 PM
