Trailblazer converter upgrade from YANK
Old Mar 27, 2005 | 08:51 AM
  #21
Yank's Avatar
LS1Tech Sponsor
Originally Posted by Justin @ EADPerformance
What can you do with an F car convertor, what do those even stall at stock. Can they be used in a truck behind a 6.0L. Reason i ask is because i have quite a few of these laying around.
Justin
the converter used in the f-body has the same stall as used in most of the trucks with the 5.3 or 6.0 engine is around 1400 to 1600 stall with a 1.9 STR
the f-body has a diff. lining on the clutch (more slip)
but the stall can be raised to 2300-2400 with 2.0 STR in a 5.3 or 6.0
we can rework them also
call me 775 826 9955 Mike or Dave
Old Mar 28, 2005 | 08:28 AM
  #22
Justin @ EAD Performance's Avatar
Thanks for the info, i think i want a little more stall then that, looks like i might be sending you a TB convertor.
Justin
Old Mar 28, 2005 | 09:04 AM
  #23
BLACKND's Avatar
So do you have any of these Re-Stalled TB converters sitting around that someone could just buy or is it pretty much just buy your own and send it in? And if so, how much would one go for?
Old Mar 28, 2005 | 09:37 AM
  #24
Yank's Avatar
LS1Tech Sponsor
This special is for you to send in your converter or drop ship one from a dealer
we do not have any of the TB cores in stock at this time only the complete new TT3000 are in stock
Old Mar 29, 2005 | 08:51 AM
  #25
BLACKND's Avatar
Cool, just thought I'd ask. How long is this good for? I am definitely interested.
Old Mar 29, 2005 | 10:57 AM
  #26
Yank's Avatar
LS1Tech Sponsor
special is good till april 30th
with the $75.00 discount
and will continue after that,but not at the special price.
it will go back to $325.00 regular price
Old Mar 29, 2005 | 11:14 AM
  #27
BLACKND's Avatar
Cool thanks for the info
Old Apr 14, 2005 | 12:27 PM
  #28
14 Second Truck Club
I wish Yank still had the 2400 unit, I'd buy it right now... Instead of having to buy another stocker, send it to them and all that BS.
Old Apr 14, 2005 | 01:03 PM
  #29
gonzo 6.2's Avatar
I had my 2400 cut open to be cleaned,I watched this converter builder inspect it before it was cleaned re-welded and balanced.According to him it was just a stock truck converter with bent fins.Next time I need a approx.2400 stall I will send the local guy a 4mi take out converter I have,and have it restalled.My cost will be around $125.The 2400 stall came with a lot of balance weight and went back together with a lot of weight,only speculating but it may have not met GM specs so it became a core that they sell to big time core buyers.BTW the converter delivers everything for my needs,I think it is max if you tow often and more than 5k lbs
Old Apr 14, 2005 | 02:03 PM
  #30
Yank's Avatar
LS1Tech Sponsor
Our 2400 truck converter is made from a special converter that GM made for EXPORT use and is not made for use in the USA, we rework the converter to our specs.
most Furnace brazed converters will need extra weight to offset the brass flows in the oven and does not mean that it is bad (brass is heavy and a small puddling will cause this)
We can not get the converters from GM any more so we have dropped that model
To the untrained eye this might look like a stock converter but it is not!
