trailblazer converter into silverado
Old 05-09-2023, 03:34 PM
  #21
Registered User
mija's Avatar
Originally Posted by tpartsman
I ended up putting in the tb converter.I am putting at least 350hp to mine, I am unsure if I love it or not. I noticed the rpms are higher before the truck moves and it has a peppy shift I also did a vette servo. I feel like I lost some torque in lower rpms. It is fun to drive though. It will smoke the tires, it will get up and go. This converter will probably be good when I get my cam. I can sit at a light and let my foot off the brake and the truck barely moves if it moves at all.
what does it take to put the TB TC in an 01 tahoe 4l60e
Old 05-09-2023, 07:12 PM
  #22
shakenfake's Avatar
Received 1,175 Likes on 895 Posts
@mija
Very simple steps
  1. Buy converter
  2. remove transmission
  3. remove original converter
  4. install new converter
  5. bolt trans in
  6. ????
  7. profit!!!
The following 3 users liked this post by shakenfake:
mija (05-09-2023), Richardman1992 (05-10-2023), strutaeng (05-10-2023)
Old 05-09-2023, 10:08 PM
  #23
Registered User
mija's Avatar
Originally Posted by shakenfake
@mija
Very simple steps
  1. Buy converter
  5. bolt trans in
  6. ????
  7. profit!!!
wow, i thought it would be more to it lol
strutaeng (05-09-2023)
Old 05-09-2023, 10:37 PM
  #24
strutaeng's Avatar
Yeah, i think it's a simple, direct swap if I skimmed through the thread correctly. The "hard" part is just doing the actual work.
Of course, you could also just call someone like Circle D or similar and give them all of your specifics like vehicle, weight, cam, gear ratio, etc., and get a torque converter ordered or custom made.
Note if it wasn't mentioned: make sure you check torque converter to flex plate spacing, 1/8" to 3/16" (obviously, also make sure converter is seated properly into the transmission pump), and make adjustments if necessary.
Old 05-10-2023, 01:42 AM
  #25
DuNnO
RDF1's Avatar
Just buy a converter for your setup. The 4.2L TB converter is barely better than stock.
getting a quality 3000 stall will make a huge difference in performance for the same amount of labor.
Old 05-10-2023, 09:49 AM
  #26
TXsilverado's Avatar
I went from 2.2 to 1.88 60' times with a trailblazer converter. Not a bad gain for the budget minded. especially if you grab one from a junk yard.
jkroberts
09-10-2013 11:17 AM
ghstface38
22
08-24-2005 08:13 PM
Searching4Sierra
08-24-2005 03:46 AM
derek_silvy
17
07-30-2004 04:21 PM
5.3Vortec
13
04-11-2004 10:10 PM
Quick Reply: trailblazer converter into silverado
