Identify GM transmission
Hi, I just purchased a used 2001 Winnebago Brave RV at a great price. However, I was told it had an allison transmission in it. That turns out to not be true. I decided to buy it anyway. The transmission that is in this RV has these numbers on the side. P/N 24208421 GM-B8. I did a quick search on and it came up with several different types of transmissions. Can anyone give me more info on this transmission? I want to change the fluid on it and the filter. What fluid? Filter? While I am at it. I need to change the differential fluid as well. Any advice?
Thanks!
Thanks!
Thanks!
Thanks!
That's a 4L80e. It actually has it cast on the case. What engine does it have? Is it gasoline? 8.1 liter perhaps?
Can't tell on the axle...🧐🤷
underwaterphoto (05-10-2023)
strutaeng (05-10-2023)
The following 3 users liked this post by RDF1:
Dexron VI is the correct fluid. You can disconnect one of the transmission cooler lines at the radiator or external cooler and hook up a clear vinyl tubing into a 5 gallon pail. Start the engine with a helper and wait until the fluid starts spitting, then shut the engine off. That will pump out most of the old fluid from the converter.
Remove the pan (now almost dry), clean the magnet and remove the filter and the little metal seal inside the transmission. The new filter for your transmission (late model) has the little feet on the bottom. Install new metal seal, filter and reuse the original thick pan gasket. Torque pan bolts to spec.
Dump about 5 quarts of new fluid and start the engine and add another 5 quarts while engine is running (have them ready.) Shift through the gears and add more as necessary.
That's the procedure I've done. Sounds kinda scary at first, but it's not once you do it the first time.
That pan has a drain bolt too, do that before removing the pan.
My opinion is just measure the amount of fluid you take out, that way you roughly know what you need to put back in. Have enough fluid on hand but just don't go dumping 10 quarts in the thing right off the bat. Fill, check with dipstick and repeat.
strutaeng (05-11-2023)
I now see you have a drain plug on the transmission pan 🧐. You can do a drain and refill. No problem.
Can you count the number of bolts on the differential? I'm thinking you have a Dana 80? It's probably an open differential, so any spec gear oil will work. Pop the cover (actually, pop the fill plug first to make sure you can actually remove it), drain fluid, use brake clean to wash any grit out. Clean the magnet and reinstall cover. You need a little hand pump to pump new fluid in until full to fill plug level.
Richard
99LoweredSierra
21
05-01-2007 11:10 PM
