trailblazer converter into silverado
Old May 9, 2023 | 03:34 PM
  #21
mija's Avatar
Registered User
Originally Posted by tpartsman
I ended up putting in the tb converter.I am putting at least 350hp to mine, I am unsure if I love it or not. I noticed the rpms are higher before the truck moves and it has a peppy shift I also did a vette servo. I feel like I lost some torque in lower rpms. It is fun to drive though. It will smoke the tires, it will get up and go. This converter will probably be good when I get my cam. I can sit at a light and let my foot off the brake and the truck barely moves if it moves at all.
what does it take to put the TB TC in an 01 tahoe 4l60e
Old May 9, 2023 | 07:12 PM
  #22
shakenfake's Avatar
Shlumpt
5 Year Member
@mija
Very simple steps
  1. Buy converter
  2. remove transmission
  3. remove original converter
  4. install new converter
  5. bolt trans in
  6. ????
  7. profit!!!
Old May 9, 2023 | 10:08 PM
  #23
mija's Avatar
Registered User
Originally Posted by shakenfake
@mija
Very simple steps
  1. Buy converter
  5. bolt trans in
  6. ????
  7. profit!!!
wow, i thought it would be more to it lol
Old May 9, 2023 | 10:37 PM
  #24
strutaeng's Avatar
5 Year Member
Yeah, i think it's a simple, direct swap if I skimmed through the thread correctly. The "hard" part is just doing the actual work.
Of course, you could also just call someone like Circle D or similar and give them all of your specifics like vehicle, weight, cam, gear ratio, etc., and get a torque converter ordered or custom made.
Note if it wasn't mentioned: make sure you check torque converter to flex plate spacing, 1/8" to 3/16" (obviously, also make sure converter is seated properly into the transmission pump), and make adjustments if necessary.
Old May 10, 2023 | 01:42 AM
  #25
RDF1's Avatar
DuNnO
5 Year Member
Just buy a converter for your setup. The 4.2L TB converter is barely better than stock.
getting a quality 3000 stall will make a huge difference in performance for the same amount of labor.
Old May 10, 2023 | 09:49 AM
  #26
TXsilverado's Avatar
I went from 2.2 to 1.88 60' times with a trailblazer converter. Not a bad gain for the budget minded. especially if you grab one from a junk yard.
jkroberts
Sep 10, 2013 11:17 AM
ghstface38
22
Aug 24, 2005 08:13 PM
Searching4Sierra
Aug 24, 2005 03:46 AM
derek_silvy
17
Jul 30, 2004 04:21 PM
5.3Vortec
13
Apr 11, 2004 10:10 PM
