traction bars compared...READ
Old Jan 24, 2008 | 12:52 PM
TXsilverado's Avatar
Default traction bars compared...READ
its another forum but its the best reading ive done in a while. youll probably have to register but its quick and easy. good info in all 9 pages.
http://www.nloc.net/vbforum/gen-2-li...tion-bars.html
Old Jan 24, 2008 | 01:06 PM
ap2002's Avatar
good find stew, only got to read 3pages though, I finish up when I get back..
Old Jan 24, 2008 | 01:09 PM
i thought this was especially interesting for those wanting longbars
domination's Avatar
Banned
That was some pretty crappy reading. None of those jerks have much a clue how that stuff works. Those diagrams are garbage.
Old Jan 24, 2008 | 01:12 PM
ap2002's Avatar
care to explain your knowledge about it?
Old Jan 24, 2008 | 01:25 PM
domination's Avatar
Banned
Based on that diagram your truck is not moving forward. Its as though the force your housing is seeing in a rotational manner is being generated improperly. The long bar diagram is incomplete. If you look just by the diagram for the long bars, the axle will not push the bar forward. It would flop over backwards. You need to consider at least the front eye of the leaf spring. Leverage pretty much needs to be triangulated to apply force and keep the axle under your truck.
Your axle undoubtedly receives the rotational torque described in the pictures, but there is now consideration that the truck is being pushed forward from the front mount points. They don't just lift.
To say that long bars generate no lifting force is asinine. Just like saying ladder bar create only a force in a 85 degree angle upwards. That graphic is beat!
Old Jan 24, 2008 | 02:54 PM
may need to read it again...they covered everything you just said in pretty good detail except for the forward motion where you lost me??? they didnt say that longbars dont work. the fastest lightnings out there run long bars.
everything ive seen says the axile would push that bar forward when the pinion angle lifts. its what the caltrack design is based on. even after the truck is moving forward those back tires are trying to drive through the truck (lifting the pinion angle, thus pushing the bars forward) maybe i read your message incorrectly?
Old Jan 24, 2008 | 03:15 PM
Mangled03gmc's Avatar
Baltimore Whore
That was a good read, if you can get by all the disputes they have and who is rite over what... if ya cut that out then it is only about 6 pages of reading.. LOL I have also read that a longer bar isn't always better, it comes down to the setup and size of the complete chassis. There is also a diagram of that floating around..
John
Old Jan 24, 2008 | 03:26 PM
yeah i was guna make some long bars but since im in an ecsb i think caltracks will work best. i just dont feel like adjusting them looking for the sweet spot. if i were in a scsb i would fab up some long bars.
Old Jan 24, 2008 | 03:30 PM
domination's Avatar
Banned
Perhaps I did jump the gun a bit. I couldn't read the whole thing. I didn't have the time and it was pissing me off with all the arguments.
I think we're on the same page about the rear axle trying to drive threw the truck, as well as rotating itself. Which ever force is greater will happen. If its just leaf springs they are strong enough to enable the rear axle to push the truck forward, but not quite strong enough to eliminate any axle rotation. When you add a lower link, both forces are going to be applied. You will get some lift from a long bar. Maybe later tonight if I get some time I'll read their whole thread.
