Traction Bars?
Old Feb 16, 2011 | 01:30 PM
URLIFEWASOC's Avatar
Default Traction Bars?
i finally sat down and used the search button a lot and read many many posts.I am trying to find some traction bars for my lifted truck i know cal tracs make some but from what i have read on some of the forums(petersen's 4 wheel & off-road) the longer the bars the better. Does any one else make a set up for my truck? I would love to spend the time and make my own but i work way too much. I am also going to order some Deaver springs soon maybe next month so i can try to finish my truck up. Reason being is because in second/third gears my truck shifts really hard. yes i had my tuner look at it and fix it the best he could but now i know it is my rear axle because of the blocks/leaf set up i have i noticed it when i drove it the past couple of days. when i drive like an old lady (which is never) the truck shifts are pretty smooth but when i drive it pretty hard it shifts hard.
so far i found these guys
http://offroaddesign.com/catalog/tractionbar.htm
http://eastsidecustomtruck.com/i-131...ted-a-d-d.html
http://lazarsmith.com/tractionbars.html
any input helps i just want to be sure that i make the right decision the first time and not have to worry about it later.
Old Feb 16, 2011 | 01:38 PM
sharpshooter's Avatar
most of the major lift companies make them
I like Cognito's economy bars.
Also Caltracs work differently than traction bars and they do make them for lifted trucks.
Old Feb 16, 2011 | 03:43 PM
Deaver springs are on the way my younger bigger brother is going to pick them up! Caltracs i am still researching into, the cognito i havent found much infomation on. any one else have an opinion on what i should be looking for?
Old Feb 16, 2011 | 04:07 PM
Atomic's Avatar
I have a gauge for that
I have some procomp bars I used for about 1000 miles I will sale you, with the mounting kit. Since I have basically a stock 5.3 I really dont need them.
...aside from that, its my opinion that as long as you arent running a block you dont really need traction bars. Lift springs basically take care of axle wrap themselves.
Old Feb 16, 2011 | 06:09 PM
Three6GMC's Avatar
Im looking into traction bars to hopefully stop the wheel hop my truck has every now and then. Havnt found any for my truck yet.
Old Feb 16, 2011 | 06:49 PM
Deaver only builds 4" and 6" springs and i have a 5" block. 4" would sit prerunner and 5" would sit *** high! So i have to go with a 4" deaver pack and a 1" block unless some one else can suggest an idea on how to get rid of the rear block?
Old Feb 16, 2011 | 07:09 PM
http://www.youtube.com/watch?v=nuQX_..._order&list=UL
I don't think springs are the fix.
Old Feb 16, 2011 | 07:27 PM
Beatdown Z's Avatar
Laid Back
Like a broken record, I'm going to suggest a shackle flip again, lol. An Offroad Design shackle flip will give you 4" of lift, combined with a one inch "zero-rate" add-a-leaf block will give you your 5 inches. The zero is somewhat required to center the axle in the wheelwell, since the shackle flip will move it forward.
http://offroaddesign.com/catalog/shacklekit.htm
Old Feb 17, 2011 | 03:26 PM
well i have the stock leaf springs still on my truck and i know that is one of the main culprits along with the block that will cause "axlewrap". So instead of a leaf pack use what they call "floating" shackle to resolve my problem? So i can use that shackle flip kit with a 1" block to get me back to a 5" lift on the rear and eliminate some of the axlewrap i am having. I am just trying to solve this problem aswell as learn something new at the same time.
Old Feb 17, 2011 | 03:46 PM
2004SSS's Avatar
hi-jack-
im about to go pro my leafs to see if it looks like that. i have 7" atlas springs and a 1" block and i will say mine rides pretty firm . towing is awesome , i also have bags but with no load id love to soften it up or reducde the bounce . what are my options ? traction bars like fabtech sells? any others?
