Torsion bar question?
Old Oct 22, 2008 | 02:08 PM
dieseltruckin2001's Avatar
Default Torsion bar question?
My truck is all stock, including tires and wheels. I was thinking about tightening the torsion bars just to level the truck out. I'm guessin it would only be about an inch or so. Would I be causing any problems by doing that? Thanks ya'll.
Old Oct 22, 2008 | 02:26 PM
If you turn them up over 3 full revolutions, you need to have it re-aligned. But no, you won't be hurting anything. It take about and inch and 3 quarters.
Old Oct 22, 2008 | 02:31 PM
Jeteys5.3's Avatar
shouldnt be an issue. I don't think you will even see a ride difference, unless you crank all the way which still be only be slighty noticable. Now if you add keys and crank thats a different story.
Go for it, it will look better.
Old Oct 22, 2008 | 10:36 PM
budhayes3's Avatar
PT's Slowest Truck
No problems, but any time you alter the ride height you should have your wheel alignment checked...and I do believe that the ride will be a bit harsher than before...
Old Oct 23, 2008 | 12:22 AM
Well, I cranked 'em three turns and brought the front up exactly and inch. Then I went and got some generic lift blocks for the back and brought the back up an inch as well. Took it out on the highway and it drives exactly the same as it did before. I couldn't even tell any difference in the ride.
thunder550
Oct 8, 2015 04:53 PM
iregret
Sep 10, 2015 09:00 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Kaldar
Jul 27, 2015 06:42 PM
signguy62
Jul 25, 2015 03:12 PM
