Torque is a major factor into stall speed
Old Nov 28, 2007 | 03:24 PM
brodystruck's Avatar
Default Torque is a major factor into stall speed
But how much of a difference does it make? On your average convertor how much is the flash stall speed going to increase going from a smaller motor (4.8) to a larger motor (6.0)?
We talking 200RPMs or closer to 1000?
Old Nov 29, 2007 | 09:56 AM
BigKID's Avatar
There is really no exact measurement as it varies with converter configuration, amount of torque increase and weight of vehicle. If the converter is a large diameter and is very tight to start with, a small increase will be noticed from the increased torque. If the converter is a small diameter and really loose the difference will be more pronounced.
Old Nov 29, 2007 | 10:32 PM
Wilde Racing's Avatar
How do I change this text
I would guess 1000 range maybe lower.
My stock 80e would brake stall to about 2,000 rpm with the LQ4, I'd have to wait for the turbo to build boost and it would creap up to over 3200......
Old Nov 30, 2007 | 09:32 AM
BLACKND's Avatar
This is a good topic and hopefully more light can be shed.
I am currently trying to decide on a converter for my 07 4.8 liter, but don't know what to go with. I plan on eventually going with a smaller cam, like a comp 206/212 112 LSA or something similar. I don't want to go with a huge converter preferably 2600-2800 RPM, but I also want it to work with the cam.
I'd like to go with a trailblazer converter, but don't know how it would work behind a 4.8 liter.
Old Nov 30, 2007 | 11:03 AM
ap2002's Avatar
good topic, my fuddle in my 5.3 was flashing at 3300-3400rpm, now in the 6.0 it flashes at 3900-4000rpm....
Old Nov 30, 2007 | 05:59 PM
03sierraslt's Avatar
I have always wondered how much additional TQ it took before you would notice the stall speed change.
Old Nov 30, 2007 | 06:32 PM
My fuddle was flashing to about 2400 with the 4.8L and bolt-ons (this was at the drag strip on 28x10.50x15 slicks). I'm hoping for at least a 3000 flash with slicks with the cammed 6.0L
Old Nov 30, 2007 | 09:02 PM
TURBHOE's Avatar
i have a good question. who all here can sit at a stop light come to a complete stop. slowly release the brakes and sit perfectly still. i'm talking flat road in drive.
i think wieght and traction (brakes)nhave alot to do with it. my silverado 4wd would stall up to about 3000. with the same converter in my hoe (i took it out of the truck and installed to tahoe) it will stall to about 3200-3300. truck had a cammed ls1 tahoe is stock 5.3l.
Old Dec 1, 2007 | 09:57 AM
SlvrSierra4.8's Avatar
What fuddle stall were you running?
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Aug 31, 2015 05:49 PM
noproblems209
Aug 10, 2015 06:57 PM
Sales4@Texas-Speed
Aug 3, 2015 03:57 PM
