Torque Converter Slipping/Surging
Old Jun 24, 2006 | 10:41 AM
Injected1's Avatar
Default Torque Converter Slipping/Surging
Ok, when my converter locks up at 40mph if I try to accelerate at all with the converter locked up I get this nasty surging, like the computer can't decide wether or not it wants to leave the converter locked, or un-lock it. I have a Fuddle 3000 stall. And right now, I am really worried about burning up the lock-up clutch. Any suggestions? (PS I have HP Tuners, so if there is something I can do in the tune)
Old Jun 24, 2006 | 10:44 AM
Colby 04's Avatar
Matt and Beau were discussing this offline the other day....I think Matt said there was something in the tuning that could be done about the lockup settings to correct it. I wish I knew though...
Injected1's Avatar
Did they mention something about modifying the duty cycle?
Old Jun 24, 2006 | 10:52 AM
Colby 04's Avatar
I don't know the details...I was just trying to give you a lead
didn't mean to tease you though
Old Jun 24, 2006 | 11:22 AM
Injected1's Avatar
its cool...hoping you can remember...mention this thread to them if you see them...I am going to bend some wrenches now...
Old Jun 24, 2006 | 11:32 AM
dewmanshu's Avatar
Moderately Differentiated
no other trans modifications? Did this problem just come up or have you modded something and then you had surging lockup issues?
You can change the minimum duty cycle to like 80 accross the board, but I have an 80e and shift and HD parts. I am not sure what the correct suggest is on that though. I am sure afuddle can handle 80 across the board. Not that this is your problem.
If you just threw in the fuddle and have stock lockup settings. you may need some tweaking to those tables.
Old Jun 27, 2006 | 12:27 PM
Injected1's Avatar
its a fuddle and rock-on trans...its always seem to have done it when the trans is warmed-up
Old Jun 27, 2006 | 02:21 PM
Nick™'s Avatar
does it do it at a particular speed? you can adjust the TCC lockup numbers in the tune to work around common cruising speeds, you don't want it locking and unlocking too close to each other - especially at common cruising speeds
99bluefirebird
Sep 17, 2015 08:05 PM
jtphelps289
Sep 11, 2015 06:37 PM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
