Tires for a 2/4 Drop with 20's ???
Old Feb 8, 2006 | 02:46 PM
StrokerAce03's Avatar
285/50 fits perfect on a 8" rim. Looks good with a 2/4 drop as well; probably what I'm going with.
Old Feb 8, 2006 | 07:07 PM
Post
I see that all you guys got your thumbnails from Tire Racks web site.
I found the 295/ 45/ 20 the same day.
The Continental Sport Contact would be a better tire due to it's tire specs.
I've been working with tires over 5 years. Know a little bit about the specs on the tires.
Just not knowledgable about every different size out there, but give me the specs & a pic of the tire and I can tell you what and how the tire will drive in rain, dry, cold weather, hot weather, snow, ice, how long it will last compared to another tire's specs, the traction, and so on.
The 285/ 50/ 20 should look good at that drop. Wouldn't try any larger in the front. The 295/ 45/ 20 "may" rub a bit on the front plastic splash guards (due to increase in the width) and will probably show more of a fender gap (due to the lower profile). Just compare both both rolling diameter specs.
The 295/ 45/ 20 tire's rolling diameter will be about 30.4-30.5" (different tire brands vary a tad)
The 285/ 50/ 20 tire's rolling diameter will be about 31.2".
Therefore, the 285/ 50/ 20 will fill the fender wells up a little more than the 295/ 45/ 20.
Jim
Jim
Old Feb 9, 2006 | 05:42 AM
tdrumm's Avatar
285/50/20 looks too beefy on a 2wd lowerd 2/4, IMO
265/50/20 - BFG, Toyo, Goodyear, Falken all make tires in this size. I run Toyos in this size, same wheels, same drop, same truck.
Old Feb 9, 2006 | 06:13 AM
SnakeOiler's Avatar
Originally Posted by 04BlackSilverado
Heres the deal, 2WD, 2/4 Drop, 20x8 Stingray III Wheels.....
How wide can I go without rubbing?
295/45/20 Or 265/50/20 ?
I don't want to rub when turning, and when or if I bottom out. I don't want to go any higher than 31" tall tire, or any lower than 29.5" tall.
Any recomendations??
I'm running both!! 295 in back and 265 up front. You should not run the 295/45 on that 8"rim - you need a wider rim. with the proper backspacing, the 295 will fit in front and clear everything while at rest. But I think during driving conditions it will rub the stabilizer bar and inside top fender under stress.
The 285/50, IMO, is too tall for a 2WD - better suited on a 4WD. The 265/50 will look fine all the way around with your specified. wheel.
If you really want to go wide - you will have to get more customizable wheels.
Old Feb 9, 2006 | 10:45 AM
04BlackSilverado's Avatar
I see what you mean.... i will look more into it when i get home, Thanks
Do you have pics that show the height from the side and width from the rear??
Thanks
Old Feb 9, 2006 | 11:31 AM
tdrumm's Avatar
I have one of the tire from the rear that shows the relationship between the edge of the tire and the edge of the rear quarter panel at home. The side wall is basically flush with or inside the edge of the fenderwell 1/2".
Old Feb 10, 2006 | 02:24 PM
2manytoys's Avatar
I had a set of 285/50's On a 20x9 Wheel. They looked good on just 2 inch drop out back. Prob would have been too wide for 2/4 drop.
Old Feb 10, 2006 | 02:48 PM
Post
There is also the 275/ 45/ 20. It fits nice with drops as well.
Check out the TBC Vengeance Sport tires. They look pretty cool.
I believe that only NTB sells them.
Don't think they have a pic of them on their web-site though.
The pic can possibly be found through just a search through the web.
http://www.tbcprivatebrands.com/sigm...line.asp?id=23
This is a pic of it, just has a different name on it. But it looks exactly the same.
Jim
maxspeed05V
Nov 11, 2015 04:20 PM
Lamartian92
Sep 10, 2015 09:27 PM
Lamartian92
Aug 21, 2015 01:43 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
KleanKustoms
Jul 18, 2015 10:08 PM
