Shift firmness?
Old Feb 9, 2006 | 07:51 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default 1st-2nd Chirps?
Just picked up my truck with the new Transgo and servos mod. How firm is too firm? Does it "break in".
Right now the 1-2 shift chirps my 32" tires without any effort. Is too firm hard on other parts? The 2-3 is not as brutal.
Old Feb 10, 2006 | 06:46 AM
trever1t's Avatar
How firm should it be?
Old Feb 10, 2006 | 07:21 AM
slowec's Avatar
Did you use any washers on the servo or 1/2 accumulator. You might want to rethink that if you did. Chirpin tires with a 60e will put you back in the shop if you can't go easy in it. Mine will bark 2nd , but I baby my 1/2 shift for daily driving. I sprayed the hell out of my truck on the stock 60e. 13k, I got it rebuilt, transgo hd2, 1 washer on acc. , no washers on servo. It shifted very firm for the first 2500 miles, then mellowed a little. I have 23k on it now. fluid looks great and shifts fine. Sometimes I wish I had took that washer out right after the rebuild , then other times I enjoy watching the look on the young kids face in the other lane when I pull on him and chirp em! Hope this helps.
Old Feb 10, 2006 | 07:28 AM
TeamTripp's Avatar
If your chirping your tires at part throttle, its too firm. When I build a tranny or install a TransGo, I go a little bigger on the 2nd feed orifice, and use less washers in the accumulator.
Old Feb 10, 2006 | 07:44 AM
slowec's Avatar
I didthe bigger hole too , just didn't mention it cause his kit is already installed. You do aggree with no acc. washers on a fresher trans right?
Old Feb 10, 2006 | 08:41 AM
trever1t's Avatar
Too late now, right?
I can have him back off in the tune a little?
Can i increase the 2-3 shift in the tune also?
Old Feb 10, 2006 | 04:46 PM
trever1t's Avatar
We backed off the (line pressure) 1-2 shift a little, to the point where its a good solid shift into second and increased the 2-3 to where i can feel it a little.
About how firm is good/not good? I mean if it shifts too firm am i risking damaging something?
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 06:27 AM
